The hEX PoE documents port 1 as “internet” and ports 2-5 as “LAN”. Only ports 2-5 support PoE out.
Is port 1 in some way special with respect to routing, on either hardware or OS level? Can I connect my upstream network to ports 2-5 instead? The block diagram at least shows all ports connected to the same gigabit switch.
I’m looking for something that can supply 802.3af/at power to an LTE router (Zyxel LTE7460), wondering if hEX PoE can do that.
This is just the default config that ships with RouterOS.
You will either need to modify this, or reset config with no defaults and setup your own network.
Any port can be used for anything on RouterOS, except obviously if it doesn’t do POE out it won’t.
configuration wise, the internet port is the one that has a DHCP client on it, a firewall, and some NAT rules.
the LAN ports are in a bridge, and the bridge has a DHCP server on it.
You can set any other ports to do the same things, you can even have multiple internet ports in any order.
If you have a current ROS version remove port 5 from the bridge. Add a DHCP client to port 5 and srcnat to port 5. Add firewall rules for port 5 internet connection.
Use port 5 for connection to your PoE modem.
