Can i fit and run three Dbii DB-F50-PRO to 733AH or 733?
Hi
Will i be able to fit all of the three? if yes what frequency should they run on, to dont cause interference?
Thx
733?? Not seen this product yet.
check routerboard.com
733 is not real product. Only 433 and 433AH
hahaha…
and this guy made me search routerboard.com so many times.
Appology, i must be long day. lol
you right man it is 433 or 433AH
Nope, you can not fit 3 of those cards into RB433 cause they’re too thick.
Even if the radio cards would fit, it is bad practice to use 3 cards onto one routerboard as there will be self interference as throughtput increases on the radio cards also if the board goes down it takes down whatever the radio cards are connected to.
