Can I install Router OS on my PC
I have a PC runnning CentOS that is being used for another application, can I also install Router OS on ths PC.
And if so do you have any instructions to do so ?
Thanks in advance
Piri
RouterOS is an operating system that should be run separately on a machine by it self, it is not a program that can be installed and ran.
You can use VmWare on your CentOS then INSTALL mk. That’s so funny and interesting.
Rafiq…
what is so funny and interesting about it ?
funny = easy, good and special
Interesting = OS into another OS.
Rafiq…
routeros is OS by itself it has kernel and all the necessary packages. simply put the install cd. it is ready to work. it will fromat the pc and istall ştself to the hdd or cf.
