My peered is using an internal DNS server. However, the query logs all indicate the ip address of ROS, and I canceled the masquerade for the LAN interface in NAT.
After that I couldn’t access the LAN through Wireguard.
I traced via tracert and it only traced to the Wireguard address and then the request timed out.
My configuration is as follows
Maybe you will find my grammar wrong, please don’t laugh at me, it’s from Google Translate. I’m new to networking and I enjoy the learning process even though it’s hard. Thanks for any help.
# mar/11/2023 16:06:52 by RouterOS 7.8
# software id = TI09-7WK3
add name=bridge1
set [ find default-name=ether1 ] name=lan1-lan5
set [ find default-name=ether2 ] disable-running-check=no name=wan
/interface vrrp
add comment="gatway vrrp" interface=bridge1 name=vrrp1 version=2 vrid=51
add comment="dns vrrp" interface=bridge1 name=vrrp2 version=2 vrid=52
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add name=Lan
/interface lte apn
/ip dhcp-server option
add code=3 name=Gateway-Ros value="'192.168.2.1'"
add code=3 name=Gateway-Openwrt value="'192.168.2.2'"
add code=6 name=DNSServer-3 value="'192.168.2.5'"
add code=6 name=DnsServer.1 value="'192.168.2.1'"
/ip ipsec policy group
add name=ikev2
add comment=192.168.2.10-192.168.2.200 name=dhcp_pool ranges=192.168.2.10-192.168.2.200
add name=ikev2pool ranges=10.0.3.225-10.0.3.238
add address-pool=dhcp_pool interface=bridge1 lease-time=20m name=server1
/ip ipsec mode-config
add address-pool=ikev2pool address-prefix-length=28 name=ikv2 static-dns=192.168.2.5 system-dns=no
/lora servers
add address=eu.mikrotik.thethings.industries down-port=1700 name=TTN-EU up-port=1700
add address=us.mikrotik.thethings.industries down-port=1700 name=TTN-US up-port=1700
add address=eu1.cloud.thethings.industries down-port=1700 name="TTS Cloud (eu1)" up-port=1700
add address=nam1.cloud.thethings.industries down-port=1700 name="TTS Cloud (nam1)" up-port=1700
add address=au1.cloud.thethings.industries down-port=1700 name="TTS Cloud (au1)" up-port=1700
add address=eu1.cloud.thethings.network down-port=1700 name="TTN V3 (eu1)" up-port=1700
add address=nam1.cloud.thethings.network down-port=1700 name="TTN V3 (nam1)" up-port=1700
add address=au1.cloud.thethings.network down-port=1700 name="TTN V3 (au1)" up-port=1700
/port
set 0 name=serial0
set 1 name=serial1
/ppp profile
add change-tcp-mss=yes name=autoUpdateUpnp on-up="delay 3s\r\
\n\r\
\n:execute \"updateUpnp\""
/interface pppoe-client
add add-default-route=yes disabled=no interface=wan name=pppoe-out1 profile=autoUpdateUpnp user=CD0283392346505
/routing table
add comment=wireguard disabled=no fib name=wireguard
add bridge=bridge1 interface=lan1-lan5
set discover-interface-list=Lan
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add interface=bridge1 list=Lan
add interface=vrrp1 list=Lan
add interface=vrrp2 list=Lan
add interface=wireguard1 list=Lan
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=10.0.2.2/32 comment="phone s10" interface=wireguard1 public-key="xxx"
add allowed-address=10.0.2.3/32 comment="work pc" interface=wireguard1 public-key="xxx"
add allowed-address=10.0.2.4/32 comment=xlwork_pc interface=wireguard1 public-key="xxx"
add address=192.168.2.1/24 interface=bridge1 network=192.168.2.0
add address=192.168.1.2/24 interface=wan network=192.168.1.0
add address=192.168.2.4/24 comment=gatway interface=vrrp1 network=192.168.2.0
add address=192.168.2.5/24 comment=dns interface=vrrp2 network=192.168.2.0
add address=10.0.2.1/24 interface=wireguard1 network=10.0.2.0
/ip dhcp-server lease
add address=192.168.2.115 client-id=1:0:11:32:b5:61:bf dhcp-option=Gateway-Ros lease-time=1d mac-address=00:11:32:B5:61:BF server=server1
add address=192.168.2.237 client-id=1:68:77:24:96:92:42 comment=tp_video mac-address=68:77:24:96:92:42 server=server1
add address=192.168.2.2 dhcp-option=Gateway-Ros mac-address=00:0C:29:D3:52:8D server=server1
add address=192.168.2.3 client-id=ff:9f:6e:85:24:0:2:0:0:ab:11:71:44:f9:1c:d7:a9:37:67 mac-address=00:0C:29:EB:E8:6C server=server1
add address=192.168.2.0/24 dns-server=192.168.2.5,192.168.2.3 gateway=192.168.2.4 netmask=24
set allow-remote-requests=yes servers=114.114.114.114,2400:3200::1,2400:3200:baba::1
/ip firewall address-list
add address=192.168.2.115 comment=nas list=upnp
add address=192.168.2.69 comment=pc list=upnp
add address=192.168.2.3 comment=ubuntu_server list=upnp
add action=accept chain=input comment="allow lan ping" in-interface=bridge1 protocol=icmp
add action=drop chain=input comment="allow upnp" dst-port=1900 in-interface=bridge1 protocol=udp src-address-list=!upnp
add action=drop chain=input comment="allow upnp" dst-port=2828 in-interface=bridge1 protocol=tcp src-address-list=!upnp
add action=drop chain=input comment="drop invalid" connection-state=invalid
add action=drop chain=input comment="Drop Ax3600 dns " dst-port=53 protocol=udp src-address=192.168.2.96 src-address-list=""
add action=accept chain=input comment="allow gatwayarrp input" in-interface=vrrp1
add action=accept chain=input comment="allow dnsarrp input" in-interface=vrrp2
add action=accept chain=input comment="accept established,related,untracked" connection-state=established,related,untracked
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=input comment="drop wan dns search" dst-port=53 in-interface=pppoe-out1 protocol=udp
add action=drop chain=forward comment="drop forward invalid conn" connection-state=invalid
add action=drop chain=forward comment="drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface=pppoe-out1
add action=accept chain=input dst-port=13231 in-interface=pppoe-out1 protocol=udp
add action=accept chain=input in-interface=pppoe-out1 protocol=ipsec-ah
add action=accept chain=input in-interface=pppoe-out1 protocol=ipsec-esp
add action=accept chain=input dst-port=4500 in-interface=pppoe-out1 protocol=udp
add action=accept chain=input dst-port=500 in-interface=pppoe-out1 protocol=udp
add action=drop chain=input comment="drop all wan" in-interface=pppoe-out1
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address=192.168.2.2 new-routing-mark=*400 passthrough=yes src-address=10.0.0.10
add action=accept chain=prerouting dst-address=192.168.1.0/24 src-address=192.168.2.0/24
add action=mark-routing chain=prerouting dst-address=!192.168.2.0/24 new-routing-mark=wireguard passthrough=yes src-address=10.0.2.0/24
add action=masquerade chain=srcnat dst-address=192.168.1.0/24 src-address=192.168.2.0/24
add action=masquerade chain=srcnat disabled=yes dst-address=192.168.2.0/24 out-interface=!bridge1
add action=masquerade chain=srcnat out-interface-list=!Lan
add action=dst-nat chain=dstnat comment="ubuntu" dst-port=2222 in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.2.3 to-ports=22
add action=dst-nat chain=dstnat comment="ubuntu_10001" dst-port=10001 in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.2.3 \
to-ports=10001
add action=dst-nat chain=dstnat disabled=yes dst-port=4500 in-interface=pppoe-out1 protocol=udp to-addresses=192.168.2.3 to-ports=4500
add action=dst-nat chain=dstnat disabled=yes dst-port=500 in-interface=pppoe-out1 protocol=udp to-addresses=192.168.2.3 to-ports=500
add action=dst-nat chain=dstnat dst-port=5001 in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.2.115 to-ports=5001
add action=dst-nat chain=dstnat disabled=yes dst-address=192.168.2.1 dst-port=6054 in-interface=bridge1 protocol=udp to-addresses=192.168.2.1 to-ports=53
add action=dst-nat chain=dstnat dst-port=3333 in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.2.99 to-ports=22
add action=dst-nat chain=dstnat dst-port=9998 in-interface=pppoe-out1 protocol=tcp to-addresses=10.0.0.100 to-ports=5001
add action=dst-nat chain=dstnat dst-port=9997 in-interface=pppoe-out1 protocol=tcp to-addresses=10.0.0.100 to-ports=9997
add action=dst-nat chain=dstnat dst-port=9996 in-interface=pppoe-out1 protocol=tcp to-addresses=10.0.0.100 to-ports=9996
/ip firewall raw
add action=add-src-to-address-list address-list=PSD address-list-timeout=none-dynamic chain=prerouting comment="psd\B6\CB\BF\DA\C9\A8\C3\E8" in-interface=\
pppoe-out1 protocol=tcp psd=21,3s,3,1
add action=drop chain=prerouting comment="psd" src-address-list=PSD
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.2 pref-src=0.0.0.0 routing-table=wireguard scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=10.0.2.0/24 gateway=wireguard1 pref-src=0.0.0.0 routing-table=wireguard scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=pppoe-out1 pref-src="" routing-table=wireguard scope=30 suppress-hw-offload=no target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.2.0/24
set ssh disabled=yes
set api disabled=yes
set winbox address=192.168.2.0/24
set api-ssl disabled=yes
/ip smb
set allow-guests=no
/ip upnp
set allow-disable-external-interface=yes enabled=yes
/ip upnp interfaces
add interface=bridge1 type=internal
add interface=pppoe-out1 type=external
/ipv6 address
# address pool error: pool not found: v6pool (4)
add eui-64=yes from-pool=v6pool interface=bridge1
/ipv6 dhcp-client
add add-default-route=yes interface=pppoe-out1 pool-name=v6pool pool-prefix-length=60 request=prefix use-peer-dns=no
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
/ipv6 nd
set [ find default=yes ] managed-address-configuration=yes other-configuration=yes
add disabled=yes interface=bridge1 mtu=1492 other-configuration=yes
/routing rule
add action=lookup disabled=no interface=wireguard1 src-address=10.0.2.0/24 table=*400
/system clock
set time-zone-name=Asia/Shanghai
/system hardware
set allow-x86-64=yes
/system identity
set name=Nextadmin.net
/system logging
add disabled=yes topics=upnp
add disabled=yes topics=dhcp
add disabled=yes topics=ipsec
/system ntp client
set enabled=yes
/system ntp server
set broadcast=yes broadcast-addresses=192.168.2.255 enabled=yes
/system ntp client servers
add address=ntp.aliyun.com
add address=ntp1.aliyun.com
add address=ntp2.aliyun.com
/system scheduler
add interval=2d name="\B6\A8\CA\B1\D6\D8\B2\A5" on-event="/interface disable pppoe-out1\r\
\n/interface enable pppoe-out1" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=jun/29/2022 start-time=04:00:00
/system script
add dont-require-permissions=no name=updateUpnp owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":global addold\r\
\n:global addnew\r\
\n:set addnew [/interface get [/interface find name=\"pppoe-out1\"] running]\r\
\n:if (\$addnew=true) do={\r\
\n:set addold [/ip address get [/ip address find dynamic=yes interface=\"pppoe-out1\"] address]\r\
\n:set addold [:pick \$addold 0 ([:len \$addold ] -3)]\r\
\n/ip firewall nat set [find dynamic=yes comment ~\"^upnp*.\"] dst-address=\$addold\r\
\n}"
/tool graphing interface
add interface=lan1-lan5
/tool mac-server
set allowed-interface-list=Lan
/tool mac-server mac-winbox
[admin@Nextadmin.net] >
