can not activate www-ssl service
Hi, I cant figure out why, but the www-ssl service is in invalid state.
Its hAP ac^3 router. On other router (same model, just different ISP) there is no problem in activating www-ssl service.
 /ip service print
 #   NAME                PORT ADDRESS                                                   CERTIFICATE
 0   telnet                23
 1   ftp                   21
 2   www                   80
 3   ssh                   22
 4 I www-ssl              443                                                           ssl-web-managment
 5   api                 8728
 6   winbox              8291
 7   api-ssl             8729                                                           none
Is there some way to see some logs, why the www-ssl is invalid?
If I change the port to other number than 443 then its ok. Is there a way to find if the 443 port is used by some other service?
Do you perhaps have a port forward on port 443?
Anything in the logging?
not - as far as I can tell, I see nothing in log … more or less simple setup
/ip firewall nat> print
 0    ;;; defconf: masquerade
      chain=srcnat action=masquerade out-interface-list=WAN ipsec-policy=out,none
 1    ;;; masq. vpn traffic
      chain=srcnat action=masquerade src-address=192.168.89.0/24
Have you tried rebooting?
after reboot, still the same…
However if I try to connect from chrome i get:
This site can’t provide a secure connection192.168.1.1 uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
ok solved - no idea why, but the sstp-server was enabled…
 /interface sstp-server server set enabled=no
solved the problem
