Can ping container from terminal but not PC
Edit: I made a mistake - I cannot ping 192.168.10.44 even from the WinBox terminal. I was pinging the wrong address. So… I can ping the bridge from Terminal and a PC, but not the Pi-hole in the container. Sounds like it either isn’t really running, or I just can’t get to it even on the router. Now I know that I’ll dig more.
I’ve installed Pi-hole on an RB5009 with ROS 7.18 according to the instructions here: https://help.mikrotik.com/docs/spaces/ROS/pages/84901929/Container
The only change (at first) was using IP addresses 192.168.10.1 (container bridge) and 192.168.10.44 (veth1). I also later changed the veth1 from /32 to /24, to see if it helped. It didn’t.
The container is shown as running. I can ping (Edit: no I can’t) the veth1 .44 from a terminal in WinBox. I cannot ping it from a PC, nor can I open the Pi-hole page. I can ping the container bridge .1 from the PC (and the terminal, obviously).
Can anyone point me in the right direction?
I do have VLANs set up, but I can’t see how that should stop this working unless I’m missing something. (which I obviously am).
I’m at a loss now… been playing with it for several hours and got nowhere. Torch on veth1 showed some activity while pinging from the PC (the icmp req and an arp). I did a packet capture on veth1 while pinging and got the following (192.168.1.15 is my PC):
This is my config export, with some minor parts redacted (mainly the ipv6 config which I doubt is anything to do with it).
/container mounts
add dst=/etc/pihole name=etc_pihole src=/usb1/etc
add dst=/etc/dnsmasq.d name=dnsmasq_pihole src=/usb1/etc-dnsmasq.d
add name=B1 protocol-mode=none vlan-filtering=yes
add name=containers
set [ find default-name=ether1 ] loop-protect=off name=Eth1-LAN_Sw1-26
set [ find default-name=ether2 ] loop-protect=off name=Eth2-IoT_Sw1-25
set [ find default-name=ether3 ] name=Eth3-LAN_PH1
set [ find default-name=ether4 ] name=Eth3-LAN_PH2
set [ find default-name=ether5 ] name=Eth5-Proxmox
set [ find default-name=ether6 ] name=Eth6-VOIP poe-out=off
set [ find default-name=ether7 ] name=Eth7-WiFi
set [ find default-name=ether8 ] name=Eth8-WAN
set [ find default-name=sfp-sfpplus1 ] name=SFP
/interface pppoe-client
add add-default-route=yes allow=pap,chap disabled=no interface=Eth8-WAN keepalive-timeout=disabled max-mru=1508 max-mtu=1508 name=WAN use-peer-dns=yes user=[redacted]
/interface 6to4
add !keepalive local-address=[redacted] mtu=1480 name=HET remote-address=[redacted]
/interface veth
add address=192.168.10.44/24 gateway=192.168.10.1 gateway6="" name=veth1
/interface vlan
add interface=B1 loop-protect=off name=IoT vlan-id=3
add interface=B1 loop-protect=off name=LAN vlan-id=2
add interface=B1 loop-protect=off name=VOIP vlan-id=4
add include=none name=RestrictedVLANs
add name=LAN_DHCP_Pool ranges=192.168.1.120-192.168.1.149
add name=IoT_DHCP_Pool ranges=192.168.3.120-192.168.3.149
add name=VOIP_DHCP_Pool ranges=192.168.4.120-192.168.4.149
add address-pool=IoT_DHCP_Pool interface=IoT lease-time=23h59m59s name=IoT_DHCP
add address-pool=LAN_DHCP_Pool interface=LAN lease-time=23h59m59s name=LAN_DHCP
add address-pool=VOIP_DHCP_Pool interface=VOIP lease-time=23h59m59s name=VOIO_DHCP
/container
add envlist=pihole_envs interface=veth1 mounts=etc_pihole,dnsmasq_pihole root-dir=usb1/pihole workdir=/
/container config
set registry-url=https://registry-1.docker.io tmpdir=usb1/pull
/container envs
add key=TZ name=pihole_envs value=Europe/London
add key=WEBPASSWORD name=pihole_envs value=[redacted]
add key=DNSMASQ_USER name=pihole_envs value=root
add bridge=B1 frame-types=admit-only-untagged-and-priority-tagged interface=Eth1-LAN_Sw1-26 pvid=2
add bridge=B1 frame-types=admit-only-untagged-and-priority-tagged interface=Eth2-IoT_Sw1-25 pvid=3
add bridge=B1 frame-types=admit-only-untagged-and-priority-tagged interface=Eth3-LAN_PH1 pvid=2
add bridge=B1 frame-types=admit-only-untagged-and-priority-tagged interface=Eth3-LAN_PH2 pvid=2
add bridge=B1 interface=Eth5-Proxmox pvid=2
add bridge=B1 frame-types=admit-only-untagged-and-priority-tagged interface=Eth6-VOIP pvid=4
add bridge=B1 frame-types=admit-only-vlan-tagged interface=Eth7-WiFi
add bridge=containers interface=veth1
/interface bridge vlan
add bridge=B1 tagged=B1,Eth7-WiFi vlan-ids=2
add bridge=B1 tagged=B1,Eth7-WiFi vlan-ids=3
add bridge=B1 tagged=B1,Eth5-Proxmox vlan-ids=4
add interface=IoT list=RestrictedVLANs
add interface=VOIP list=RestrictedVLANs
add address=192.168.1.254/24 interface=LAN network=192.168.1.0
add address=192.168.3.254/24 interface=IoT network=192.168.3.0
add address=192.168.4.254/24 interface=VOIP network=192.168.4.0
add address=192.168.10.1/24 interface=containers network=192.168.10.0
add address=192.168.1.0/24 dns-server=192.168.1.45,192.168.1.46 domain=[redacted] gateway=192.168.1.254
add address=192.168.3.0/24 dns-server=1.1.1.1 domain=[redacted] gateway=192.168.3.254
set allow-remote-requests=yes servers=1.1.1.1
/ip firewall address-list
add address=0.0.0.0/8 comment=RFC6890 list=NotPublic
add address=10.0.0.0/8 comment=RFC6890 list=NotPublic
add address=100.64.0.0/10 comment=RFC6890 list=NotPublic
add address=127.0.0.0/8 comment=RFC6890 list=NotPublic
add address=169.254.0.0/16 comment=RFC6890 list=NotPublic
add address=172.16.0.0/12 comment=RFC6890 list=NotPublic
add address=192.0.0.0/24 comment=RFC6890 list=NotPublic
add address=192.0.2.0/24 comment=RFC6890 list=NotPublic
add address=192.168.0.0/16 comment=RFC6890 list=NotPublic
add address=192.88.99.0/24 comment=RFC3068 list=NotPublic
add address=198.18.0.0/15 comment=RFC6890 list=NotPublic
add address=198.51.100.0/24 comment=RFC6890 list=NotPublic
add address=203.0.113.0/24 comment=RFC6890 list=NotPublic
add address=224.0.0.0/4 comment=RFC4601 list=NotPublic
add address=240.0.0.0/4 comment=RFC6890 list=NotPublic
add address=192.168.1.30 list=CCTV
add address=192.168.1.31 list=CCTV
add address=192.168.1.214 list=NAS
add address=192.168.1.215 list=NAS
add address=192.168.1.216 list=NAS
add address=192.168.1.217 list=NAS
add address=192.168.1.44 list=stat20
add address=192.168.1.45 list=stat20
add address=192.168.1.46 list=stat20
add address=192.168.4.1 list=stat20
add action=fasttrack-connection chain=forward comment="Fasttrack Established, Related" connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="Allow Established, Related" connection-state=established,related
add action=drop chain=forward comment="Drop Invalid" connection-state=invalid protocol=tcp
add action=drop chain=forward comment="Drop non-public destinations going to WAN" dst-address-list=NotPublic log-prefix=privateip out-interface=WAN
add action=jump chain=forward comment="NAS Forward VPN checks" jump-target=nas out-interface=WAN src-address-list=NAS
add action=jump chain=forward comment="CCTV Forward checks" in-interface=LAN jump-target=CCTV out-interface=WAN src-address-list=CCTV
add action=drop chain=forward comment=SonyTV_to_WAN disabled=yes out-interface=WAN src-mac-address=[redacted]
add action=fasttrack-connection chain=forward comment="Fastrack Anything > WAN" hw-offload=yes out-interface=WAN
add action=accept chain=forward comment="Allow LAN to anywhere" in-interface=LAN
add action=accept chain=forward comment="Allow Containers Anywhere" in-interface=containers
add action=accept chain=forward comment="Allow Restricted VLANs > WAN" in-interface-list=RestrictedVLANs out-interface=WAN
add action=jump chain=forward comment="WAN Forward ICMP checks" in-interface=WAN jump-target=icmp protocol=icmp
add action=accept chain=forward comment="Allow internal ICMP anywhere" protocol=icmp
add action=drop chain=forward comment="Drop Restricted VLANs jumping" in-interface-list=RestrictedVLANs
add action=drop chain=forward comment="Drop at end for In-WAN" in-interface=WAN
add action=drop chain=input comment="Drop Invalid connections" connection-state=invalid
add action=accept chain=input comment="Allow Established, Related" connection-state=established,related
add action=accept chain=input comment="Allow from LAN" in-interface=LAN
add action=jump chain=input comment="WAN Input ICMP checks" in-interface=WAN jump-target=icmp protocol=icmp
add action=accept chain=input comment="Allow ICMP Internally" icmp-options=8:0-255 protocol=icmp
add action=drop chain=input comment="Drop at End for Input chain"
add action=accept chain=icmp comment="ThinkBroadband Ping" dst-address=[redacted] icmp-options=8:0-255 protocol=icmp src-address=[redacted]
add action=accept chain=icmp comment="Allow ICMP from HE" dst-address=[redacted] protocol=icmp src-address=[redacted]
add action=accept chain=icmp comment="Allow Echo Reply" icmp-options=0:0-255 protocol=icmp
add action=accept chain=icmp comment="Allow Destination Unreachable" icmp-options=3:0-255 protocol=icmp
add action=accept chain=icmp comment="Allow Time Exceeded" icmp-options=11:0-255 protocol=icmp
add action=drop chain=icmp comment="Final drop for WAN ICMP"
add action=accept chain=nas comment="NAS VPN port" dst-port=1912 protocol=udp
add action=accept chain=nas comment="NAS VPN Port" dst-port=443 protocol=udp
add action=accept chain=nas comment="NAS DNS" dst-port=53 protocol=udp
add action=drop chain=nas comment="Drop NAS > WAN direct" out-interface=WAN
add action=accept chain=CCTV comment="Only allow CCTV to DNS and email on WAN" dst-port=53 protocol=udp
add action=accept chain=CCTV dst-port=587 protocol=tcp
add action=drop chain=CCTV log=yes log-prefix=Cam
add action=src-nat chain=srcnat out-interface=WAN src-address=192.168.1.2 to-addresses=[redacted]
add action=src-nat chain=srcnat out-interface=WAN src-address=192.168.1.11 to-addresses=[redacted]
add action=src-nat chain=srcnat out-interface=WAN src-address=192.168.1.15 to-addresses=[redacted]
add action=src-nat chain=srcnat out-interface=WAN src-address-list=stat20 to-addresses=[redacted]
add action=src-nat chain=srcnat out-interface=WAN src-address=192.168.0.0/16 to-addresses=[redacted]
add action=masquerade chain=srcnat disabled=yes src-address=192.168.10.0/24
add action=dst-nat chain=dstnat dst-address=8.8.8.8 dst-port=53 protocol=udp to-addresses=192.168.1.45 to-ports=53
add action=dst-nat chain=dstnat dst-address=8.8.4.4 dst-port=53 protocol=udp to-addresses=192.168.1.45 to-ports=53
/ip firewall service-port
set tftp disabled=yes
set h323 disabled=yes
set pptp disabled=yes
/system clock
set time-zone-name=Europe/London
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
/system ntp client servers
add address="0.uk.pool.ntp.org 1.uk.pool.ntp.org"
add address=192.168.1.43
/tool sniffer
set file-name=pcap02 filter-interface=veth1
this forward rule only allows packet forward to containers bridge, not to its members (veth interfaces are not L2). Instead this rule create forward rule for containers address range in dst-address if you need to access all containers.
I made a mistake - I can’t even ping the Pi-hole in the container from a terminal in WinBox. I was pinging the wrong address (which replied).
I did try adding rules to accept 192.168.10.44 as both destination, and source, addresses and put them at the very top of my rules. I still could not ping .44 from anywhere.
I’ll investigate more now I know I made a mistake and can’t even ping the Pi-hole from Terminal.
Did you restart the container after changing 192.168.10.44/32 to 192.168.10.44/24?
You can run
/container/print
Note the number (for instance 0) then open the shell with that number
/container/shell 0
and try pinging 192.168.10.1 from there.
I didn’t restart, but I just did. Never thought of that (I’ve never used docker or containers before).
It worked - I can ping and access the Pi-hole page from my PC now.
Thank you!
Now I can sort out my firewall rules.
