Hello everyone,
I have an L009UiGS-2HaxD and made some changes to the default configuration.
My internet provider requires VLAN 300 on the WAN interface which i managed to add to the configuration with the following lines:
/interface vlan
add interface=ether1 name=vlan300 vlan-id=300
/ip dhcp-client
add interface=vlan300 add-default-route=yes disabled=no use-peer-dns=no use-peer-ntp=no
add action=accept chain=input in-interface=vlan300 protocol=icmp
add action=accept chain=input connection-state=established,related
add action=drop chain=input in-interface=vlan300
add action=masquerade chain=srcnat out-interface=vlan300
I can ping internet e.g: 8.8.4.4 but can’t visit any webpages.
Is there a way to fix my router config?
This is my config here below:
2025-07-31 17:36:07 by RouterOS 7.19.4
software id = [redacted]
model = L009UiGS-2HaxD
serial number = [redacted]
add admin-mac=78:9A:18:B5:AE:32 auto-mac=no comment=defconf name=bridge
port-cost-mode=short
/interface wifi
set [ find default-name=wifi1 ] channel.band=2ghz-ax .skip-dfs-channels=
10min-cac .width=20/40mhz configuration.mode=station .ssid=Mikrotik
disabled=no security.authentication-types=wpa2-psk,wpa3-psk
/interface vlan
add comment=“Odido VLAN 300” interface=ether1 name=vlan300 vlan-id=300
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=ether6 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=ether7 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=ether8 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=sfp1 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10
path-cost=10
set udp-timeout=10s
add comment=defconf interface=vlan300 list=WAN
/interface ovpn-server server
add mac-address=FE:FB:17:61:FB:34 name=ovpn-server1
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
/ip dhcp-client
add comment=defconf default-route-tables=main interface=vlan300 use-peer-dns=
no use-peer-ntp=no
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
/ip firewall address-list
add address=192.168.88.0/24 list=MGMT-RANGES
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment=“defconf: masquerade”
/ip ipsec profile
/ip service
set telnet disabled=yes
set ssh port=2202
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
add address=::/128 comment=“defconf: unspecified address” list=bad_ipv6
add address=::1/128 comment=“defconf: lo” list=bad_ipv6
add address=fec0::/10 comment=“defconf: site-local” list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment=“defconf: ipv4-mapped” list=bad_ipv6
add address=::/96 comment=“defconf: ipv4 compat” list=bad_ipv6
add address=2001:db8::/32 comment=“defconf: documentation” list=bad_ipv6
add address=2001:10::/28 comment=“defconf: ORCHID” list=bad_ipv6
add address=3ffe::/16 comment=“defconf: 6bone” list=bad_ipv6
/ipv6 firewall filter
invalid
add action=accept chain=input comment=“defconf: accept ICMPv6” protocol=
icmpv6
add action=accept chain=input comment=“defconf: accept UDP traceroute” port=
33434-33534 protocol=udp
“defconf: accept DHCPv6-Client prefix delegation.” dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment=“defconf: accept IKE” dst-port=500,4500
protocol=udp
add action=accept chain=input comment=“defconf: accept ipsec AH” protocol=
ipsec-ah
add action=accept chain=input comment=“defconf: accept ipsec ESP” protocol=
ipsec-esp
“defconf: accept all that matches ipsec policy” ipsec-policy=in,ipsec
“defconf: drop everything else not coming from LAN” in-interface-list=
!LAN
“defconf: drop packets with bad src ipv6” src-address-list=bad_ipv6
“defconf: drop packets with bad dst ipv6” dst-address-list=bad_ipv6
add action=drop chain=forward comment=“defconf: rfc4890 drop hop-limit=1”
add action=accept chain=forward comment=“defconf: accept ICMPv6” protocol=
icmpv6
add action=accept chain=forward comment=“defconf: accept HIP” protocol=139
add action=accept chain=forward comment=“defconf: accept IKE” dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment=“defconf: accept ipsec AH” protocol=
ipsec-ah
add action=accept chain=forward comment=“defconf: accept ipsec ESP” protocol=
ipsec-esp
!LAN
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
