Cannot access to web server from lan
Hello, I have a webserver behind a Mikrotik router and cannot access to it using the domain name from the local network, on the other hand if I access to the webserver from an external computer I can reach the webserver and watch the website.
Any idea?
Thank you very much
You probably need a hairpin nat to access the localnet server with the public ip.
http://wiki.mikrotik.com/wiki/Hairpin_NAT
Hello. I have tried to do the hairpin but wihtout success:
my firewall nat looks like this:
ip firewall nat
add action=masquerade chain=srcnat comment="default configuration" \
    out-interface=pppoe-out1
add action=dst-nat chain=dstnat dst-port=8125 in-interface=pppoe-out1 protocol=\
    tcp to-addresses=192.168.223.95 to-ports=8121
add action=dst-nat chain=dstnat dst-port=80 in-interface=pppoe-out1 protocol=\
    tcp to-addresses=192.168.223.95 to-ports=80
add action=dst-nat chain=dstnat dst-port=8084 in-interface=pppoe-out1 protocol=\
    tcp to-addresses=192.168.223.249 to-ports=80
add action=dst-nat chain=dstnat dst-port=8083 in-interface=pppoe-out1 protocol=\
    tcp to-addresses=192.168.223.251 to-ports=80
add action=dst-nat chain=dstnat dst-port=8085 in-interface=pppoe-out1 protocol=\
    tcp to-addresses=192.168.223.248 to-ports=80
add action=dst-nat chain=dstnat dst-port=8082 in-interface=pppoe-out1 protocol=\
    tcp to-addresses=192.168.223.250 to-ports=80
add action=masquerade chain=srcnat dst-address=192.168.223.95 dst-port=80 \
    out-interface=ether2-master-local protocol=tcp src-address=192.168.223.0/24
The last one is for trying to connect to the webserver, but as I told you I cannot reach it and also I cant reach the rest of the cameras using http://mydomain:80 or http://mydomain:8082 for a cam.
Where is your dstnat rule to port forward the public ip to the camera?
I’m not sure how this is going to work with your VPN.
Hello, One of the cameras is this one:
Also I can’t reach it from the LAN side using the http:/mydomain:8084
Just so I understand, your internet connection on all your VPN clients is through your VPN server?
This router connects to a ppoe server and then I have set up a pppt server for connecting some pptp clients. Nevertheless it allows connections to internal servers and cams for remote access using NAT.
The vpn clients have their own ppoe connection with an ISP.
Then any public ip does not route through your VPN, and having a rule associated with pptp-out1 isn’t going to work.
Do your VPN clients have different public ips?
Yes, they all have differents IP’s, but the vpn clients are working ok, the main problem is in this router, from the LAn of this router. I tried the hairpin_nat as you told me but it is not working for viewing our website from our lan side.
Only the lan with the server should need a hairpin nat. The other lans should be able to access the server without it IF the public ip has a dstnat to the server’s private ip.
So for achive that, I add this nat rule, but I dont get it to work:
But I think I have to add it like this, but it still is not working:
add action=masquerade chain=srcnat dst-address=myPublicIP dst-port=80 \
Forget the routers with their own public ips. They should be able to access your server.
It is the localnet with the server that is in question here. Post “/ip firewall nat” from that router.
Here you are: (the last one is the Hairpin NAT)
add action=dst-nat chain=dstnat dst-port=8081 in-interface=pppoe-out1 protocol=\
    tcp to-addresses=192.168.223.252 to-ports=80
So pppoe-out1 is your WAN interface?
What is the localnet ip of the server? 192.168.223.252 or 192.168.223.95?
The wan interface is ether1-gateway and the pppoe-out1 uses this interface for being connected with my ISP.
The local server where the page is hosted is 192.168.223.95
This dstnat is incorrect.
It should look like this:
add chain=dstnat dst-address=1.1.1.1 protocol=tcp dst-port=80 action=dst-nat to-address=192.168.223.95
Replace 1.1.1.1 with your public ip.
ok,It is working now with these nat rules:
add action=dst-nat chain=dstnat comment=\
    "hairPin NAT" \
    dst-address-type=local dst-port=0-65535 protocol=tcp to-addresses=\
    192.168.223.95 to-ports=0-65535
add action=masquerade chain=srcnat comment=\
    "hairPin NAT" \
    dst-address=192.168.223.95 dst-port=0-65535 out-interface=bridge-local \
Thank you very much for your cooperation and time.
