Hello all
I am trying to configure a guest wifi on my cAP ac but sadly had not luck with it. I did manage to configure my main private wifi. Both are provided as tagged VLAN over eth1. However clients are not able to connect to the guest wifi.
I already read quite a few threads in this forum regarding similar issues. I specifically looked into this post http://forum.mikrotik.com/t/using-routeros-to-vlan-your-network/126489/1 and the attached config file but I must be missing something.
My cAP ac is currently configured from scratch after resetting without default configuration. I am trying to configure the VLANs the “new way” via the bridge ports. Here is some basic information about my network:
- Ubiquity router 10.0.0.1/24
- Mikrotik cAP ac 10.0.0.30/24
- VLAN infrastructure 10.0.0.0/24
- VLAN private 10.10.0.0/24
- VLAN guest 10.50.0.0/24
Here is the configuration.
# jan/02/1970 08:57:59 by RouterOS 6.48.3
# software id = MES7-EWHA
# model = RBcAPGi-5acD2nD
# serial number = <redacted>
add frame-types=admit-only-vlan-tagged ingress-filtering=yes name=bridge \
protocol-mode=none vlan-filtering=yes
/interface vlan
add interface=bridge name=vlan_infrastructure vlan-id=2
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=\
WIFI-PRIVATE supplicant-identity=""
WIFI-GUEST supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
country=germany disabled=no mode=ap-bridge name=wlan_private_2ghz \
security-profile=WIFI-PRIVATE ssid=WIFI-PRIVATE
set [ find default-name=wlan2 ] band=5ghz-n/ac channel-width=20/40/80mhz-XXXX \
country=germany disabled=no mode=ap-bridge name=wlan_private_5ghz \
add disabled=no keepalive-frames=disabled mac-address=<redacted> \
master-interface=wlan_private_2ghz multicast-buffering=disabled name=\
wlan_guest_2ghz security-profile=WIFI-GUEST ssid=WIFI-GUEST \
wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
master-interface=wlan_private_5ghz multicast-buffering=disabled name=\
wlan_guest_5ghz security-profile=WIFI-GUEST ssid=WIFI-GUEST \
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged \
ingress-filtering=yes interface=wlan_private_2ghz pvid=10
ingress-filtering=yes interface=wlan_private_5ghz pvid=10
add bridge=bridge frame-types=admit-only-vlan-tagged ingress-filtering=yes \
interface=ether1
ingress-filtering=yes interface=wlan_guest_2ghz pvid=50
ingress-filtering=yes interface=wlan_guest_5ghz pvid=50
/interface bridge vlan
add bridge=bridge tagged=ether1 vlan-ids=10
add bridge=bridge tagged=bridge,ether1 vlan-ids=2
add bridge=bridge tagged=ether1 vlan-ids=50
add address=10.0.0.30/24 interface=vlan_infrastructure network=10.0.0.0
add distance=1 gateway=10.0.0.1
Best regards
