Any time I try to enable (or create) a logging rule (of any topic, to any action type), it immediately disables. Any ideas?
nevermind, i was able to figure this out. my router is a MikroNOC device and it shipped with some type of script enabled that updates the front LCD display. this script appeared to be erroring out and shutting off my logs in the process.
Hi, I have the same problem with my mikronoc router. What was the solution you found to fix this?
