Cannot ping across IPSec VPN
So I have setup a couple dozen site to site VPNs using IPSec and never had an issue. This latest one that I am trying to set up has something different and I cant seem to put my finger on what it is. I have one RB750GL(We will call this router 1) and one RB951G(Router 2) I set them both up the way I always do(The way Greg Sowell shows in his videos) and when I try to ping across to get interesting traffic and establish the connection I run into a problem. When I ping Router 2 from Router 1 under Ping Status it says admin prohibited and when I try to ping router 1 from router 2 under ping status it says packet rejected. I disabled all firewall rules on both sides and still get the same result. I have srcnat set up on both routers to go from their 192.168.xxx.xxx/24 subnet to 192.168.0.0/16. Plz HELP!
Well I found the problem. I was not selecting an interface to ping from. Once I selected bridge-local the tunnel established.
