Can't Change SFP Port Speed
I am using CCR1036-12G-4S ( RouterOS 6.0rc14 )
I am having problem in peering with Cisco 10/100 Mbps port via a 10/100 Mbps media converter. The port is getting up but I can’t ping between the port with IP of same block in point to point link. The problem seems the sfp port isn’t changing it’s speed 1Gbps to 100Mbps . Followings are my status
/interface print shows
12  R  sfp1                                ether       1500  1590       6130 D4:CA:6D:8E:9B:60
/export shows
set 12 speed=100Mbps
[admin@MikroTik] /interface ethernet> monitor sfp1
              status: link-ok
    auto-negotiation: disabled
                rate: 1Gbps
         full-duplex: yes
  sfp-module-present: yes
         sfp-rx-lose: no
        sfp-tx-fault: no
Would highly appreciate any suggestion. Thanks.
Please note the speed listed on an SFP transceiver, here: http://routerboard.com/S-31DLC20D
See how it the Data Rate says 1.25G and not 10M/100M/1000M/1.25G?
You can’t change the ‘speed’, or Data Rate of an SFP module.
