I'm very new to WiFi in routeros. I've got a brand new hAP be lite I upgraded to 7.24.7. I would like to configure it as a router giving Ethernet access to an upstream WiFi network.
This WiFi network would rely on AP from different vendors. Its security is WPAX-PSK (X being either 2 or 3). It works as simultaneously showing the same SSID name on both 2.4 and 5 GHz bands.
I want my hAP be lite to select either 5GHz or 2.4Ghz depending on signal strength as would a casual WiFi client.
I would ether1 to act as a backup uplink if uplink WiFi doesn't work for any reason, leaving ether2 to ether 4 interfaces to provide connectivity to downstream devices.
In my testings, I used my ISP box as the upstream WiFi. I alternatively used a TPLink EAP653 configured by an Omada controller. Both tests failed.
What are the main steps I should follow to implement this as I'm very confused with default mld1, wifi1 and wifi2 interfaces ?
setting "a" country is mandatory as it provides the correct wi-fi bands and radio power for that country, using the "right" country is up to your conscience
It is not clear (to me) which role you are wanting to use the devices in.
If the MIkrotik is going to "receive" internet wirelessly, since the AP is non-mikrotik, you must use one of the two radios (if signal is good enough on 5GHz it is better/faster) and set it as station-pseudobridge (if the AP is another Mikrotik you could use station-bridge, which is better), the Mikrotik is then a "client" like any other wifi device.
If - instead - the Mikrotik is going to "transmit" internet wirelessly, then it must be set as AP and the other device in a mode equivalento to station bridge/pseudobridge, which may or may not be available depending on make/model.
Strictly speaking the above "direction" of internet may be irrelevant, as - essentially - you want to somehow link two devices as if they were connected with a wire, so a PtP (point to point) connection.
Normally the device set as AP is the one connected to the internet via wire and it can serve as AP both normal clients and the other device, but choosing which may depend on position of the devices.
I'm sorry my previous was not clear enough: my end goal is my Mikrotik receiving Internet wirelessly.
I configured the Country setting in both wif1 and wifi2 (only setting it to wifi2 made my device instantly complaining with "Country mismatch with linked radio 01:23:34:56:78:ab (redacted)" where 01:23:34:56:78:ab lead to wifi1).
Changing this country didn't change the end result nor when I also changed from station to station-pseudobridge.
Looking at DHCP-Client status, I've got a red, permanent "Interface is not active" message above client which is tied to wifi2.
Well, the idea of station-pseudobridge is that the device is a bridge/switch, you are setting it as a router, with wifi1 and 2 (I would try only one radio first and only wpa2-psk first ) set as WAN and using NAT.
In this case the mode should be plain "station" and not "station-pseudobridge".
