Can't connect to my Mikrotik RB951G-2HnD
I just got my Mikrotik router RB951G-2HnD. I did upgrade version to the latest and did some configuration. After discovering I made some mistakes with configuration I did factory reset through WinBox. When I got back into I deleted ::defconf Bridge. After that I was not able to log into my router again. Did try to do hard reset using reset button but I am unable. The ACT light or any other light is not flashing. The router does make a sound and reset after ~20seconds but there is no change.
My computer is assigned with 169.254.x.x which is very strange. I also tried to connect via NetInstall but is found. I really need you help!!!
You have to release the reset button while the LED is flashing ~5-10s to apply default configuration. Even if the bridge is deleted you should still be able to connect through mac-telnet Winbox
