I’m using this http://forum.mikrotik.com/t/using-routeros-to-qos-your-network-2020-edition/66683/1 QOS2020 Optimized script, it works out of the box but I have two bridges: one for main network and other for guest wifi. I’ve tried to adapt it but when the bridge identifier mangle rules are enabler the other rules stop maarking packets thus making the queue tree useless.
/ip firewall mangle
add action=mark-connection chain=forward comment="All Connections" new-connection-mark=all-connections passthrough=yes
add action=mark-packet chain=forward comment="MAIN DOWNLOAD" connection-mark=all-connections dst-address=10.0.30.0/24 new-packet-mark=main-download passthrough=yes
add action=mark-packet chain=forward comment="GUEST DOWNLOAD" connection-mark=all-connections dst-address=10.0.20.0/24 new-packet-mark=guest-download passthrough=yes
add action=mark-packet chain=forward comment="MAIN UPLOAD" connection-mark=all-connections new-packet-mark=main-upload passthrough=yes src-address=10.0.30.0/24
add action=mark-packet chain=forward comment="GUEST UPLOAD" connection-mark=all-connections new-packet-mark=guest-upload passthrough=yes src-address=10.0.20.0/24
add action=mark-connection chain=prerouting comment=DNS connection-state=new new-connection-mark=DNS passthrough=yes port=53 protocol=udp
add action=mark-packet chain=prerouting connection-mark=DNS new-packet-mark=DNS passthrough=no
add action=mark-connection chain=postrouting connection-state=new new-connection-mark=DNS passthrough=yes port=53 protocol=udp
add action=mark-packet chain=postrouting connection-mark=DNS new-packet-mark=DNS passthrough=no
add action=mark-connection chain=prerouting comment=VOIP new-connection-mark=VOIP passthrough=yes port=5060-5062,10000-20000 protocol=udp
add action=mark-packet chain=prerouting connection-mark=VOIP new-packet-mark=VOIP passthrough=no
add action=mark-connection chain=prerouting comment=QUIC connection-state=new new-connection-mark=QUIC passthrough=yes port=80,443 protocol=udp
add action=mark-packet chain=prerouting connection-mark=QUIC new-packet-mark=QUIC passthrough=no
add action=mark-connection chain=prerouting comment=UDP connection-state=new new-connection-mark=UDP passthrough=yes protocol=udp
add action=mark-packet chain=prerouting connection-mark=UDP new-packet-mark=UDP passthrough=no
add action=mark-connection chain=prerouting comment=ICMP connection-state=new new-connection-mark=ICMP passthrough=yes protocol=icmp
add action=mark-packet chain=prerouting connection-mark=ICMP new-packet-mark=ICMP passthrough=no
add action=mark-connection chain=postrouting connection-state=new new-connection-mark=ICMP passthrough=yes protocol=icmp
add action=mark-packet chain=postrouting connection-mark=ICMP new-packet-mark=ICMP passthrough=no
add action=mark-packet chain=postrouting comment=ACK new-packet-mark=ACK packet-size=0-123 passthrough=no protocol=tcp tcp-flags=ack
add action=mark-packet chain=prerouting new-packet-mark=ACK packet-size=0-123 passthrough=no protocol=tcp tcp-flags=ack
add action=mark-connection chain=prerouting comment=HTTP connection-mark=no-mark connection-state=new new-connection-mark=HTTP passthrough=yes port=80,443 protocol=tcp
add action=mark-connection chain=prerouting connection-bytes=5000000-0 connection-mark=HTTP connection-rate=2M-100M new-connection-mark=HTTP_BIG passthrough=yes protocol=tcp
add action=mark-packet chain=prerouting connection-mark=HTTP_BIG new-packet-mark=HTTP_BIG passthrough=no
/queue type
set 0 kind=sfq
add kind=pfifo name=default-original
add kind=pcq name=bulkUp-Main pcq-classifier=src-address,dst-address,src-port,dst-port pcq-limit=770KiB pcq-total-limit=7700KiB
add kind=pcq name=bulkUp-Guest pcq-classifier=src-address,dst-address,src-port,dst-port pcq-limit=220KiB pcq-total-limit=2200KiB
/queue tree
add max-limit=68M name=GLOBAL-DOWN packet-mark=no-mark parent=global queue=default
add bucket-size=0.005 max-limit=68M name=MAIN-DOWN packet-mark=main-download parent=GLOBAL-DOWN priority=1 queue=default
add name="1. VOIP" packet-mark=VOIP parent=MAIN-DOWN priority=1 queue=default
add name="2. DNS" packet-mark=DNS parent=MAIN-DOWN priority=2 queue=default
add name="3. ACK" packet-mark=ACK parent=MAIN-DOWN priority=3 queue=default
add name="4. UDP" packet-mark=UDP parent=MAIN-DOWN priority=3 queue=default
add name="5. ICMP" packet-mark=ICMP parent=MAIN-DOWN priority=4 queue=default
add name="6. HTTP" packet-mark=HTTP parent=MAIN-DOWN priority=5 queue=default
add name="7. HTTP_BIG" packet-mark=HTTP_BIG parent=MAIN-DOWN priority=6 queue=default
add name="8. QUIC" packet-mark=QUIC parent=MAIN-DOWN priority=7 queue=default
add name="9. OTHER" packet-mark=OTHER parent=MAIN-DOWN queue=default
add bucket-size=0.005 max-limit=20M name=GUEST-DOWN packet-mark=guest-download parent=GLOBAL-DOWN priority=2 queue=default
add name="1. VOIP_GD" packet-mark=VOIP parent=GUEST-DOWN priority=1 queue=default
add name="2. DNS_GD" packet-mark=DNS parent=GUEST-DOWN priority=2 queue=default
add name="3. ACK_GD" packet-mark=ACK parent=GUEST-DOWN priority=3 queue=default
add name="4. UDP_GD" packet-mark=UDP parent=GUEST-DOWN priority=3 queue=default
add name="5. ICMP_GD" packet-mark=ICMP parent=GUEST-DOWN priority=4 queue=default
add name="6. HTTP_GD" packet-mark=HTTP parent=GUEST-DOWN priority=5 queue=default
add name="7. HTTP_BIG_GD" packet-mark=HTTP_BIG parent=GUEST-DOWN priority=6 queue=default
add name="8. QUIC_GD" packet-mark=QUIC parent=GUEST-DOWN priority=7 queue=default
add max-limit=70M name=GLOBAL-UP parent=global queue=default
add bucket-size=0.005 max-limit=70M name=MAIN-UP packet-mark=main-upload parent=GLOBAL-UP priority=1 queue=default
add name="1. VOIP_" packet-mark=VOIP parent=MAIN-UP priority=1 queue=default
add name="2. DNS_" packet-mark=DNS parent=MAIN-UP priority=2 queue=default
add name="3. ACK_" packet-mark=ACK parent=MAIN-UP priority=3 queue=default
add name="4. UDP_" packet-mark=UDP parent=MAIN-UP priority=3 queue=default
add name="5. ICMP_" packet-mark=ICMP parent=MAIN-UP priority=4 queue=default
add name="6. HTTP_" packet-mark=HTTP parent=MAIN-UP priority=5 queue=bulkUp-Main
add name="7. HTTP_BIG_" packet-mark=HTTP_BIG parent=MAIN-UP priority=6 queue=bulkUp-Main
add name="8. QUIC_" packet-mark=QUIC parent=MAIN-UP priority=7 queue=bulkUp-Main
add name="9. OTHER_" packet-mark=OTHER parent=MAIN-UP queue=bulkUp-Main
add bucket-size=0.005 max-limit=20M name=GUEST-UP packet-mark=guest-upload parent=GLOBAL-UP priority=2 queue=default
add name="1. VOIP_GU" packet-mark=VOIP parent=GUEST-UP priority=1 queue=default
add name="2. DNS_GU" packet-mark=DNS parent=GUEST-UP priority=2 queue=default
add name="3. ACK_GU" packet-mark=ACK parent=GUEST-UP priority=3 queue=default
add name="4. UDP_GU" packet-mark=UDP parent=GUEST-UP priority=3 queue=default
add name="5. ICMP_GU" packet-mark=ICMP parent=GUEST-UP priority=4 queue=default
add name="6. HTTP_GU" packet-mark=HTTP parent=GUEST-UP priority=5 queue=bulkUp-Guest
add name="7. HTTP_BIG_GU" packet-mark=HTTP_BIG parent=GUEST-UP priority=6 queue=bulkUp-Guest
add name="8. QUIC_GU" packet-mark=QUIC parent=GUEST-UP priority=7 queue=bulkUp-Guest
add name="9. OTHER_GU" packet-mark=OTHER parent=GUEST-UP queue=bulkUp-Guest
