Hello All
When I connect through VPN I cant ping to any device in the LAN network
tried change ARP on LAN to proxy-arp and nothing changed
set [ find default-name=ether10 ] arp=proxy-arp name=LAN
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] name=WAN2
set [ find default-name=ether3 ] name=WAN3
set [ find default-name=ether4 ] name=WAN4
add name=dhcp_pool1 ranges=10.0.0.2-10.0.0.254
add address-pool=dhcp_pool1 authoritative=after-2sec-delay disabled=no \
interface=LAN lease-time=1w name=dhcp1
/ppp profile
add dns-server=8.8.8.8,8.8.4.4 idle-timeout=1h local-address=10.0.0.1 name=\
VPN_Profile remote-address=dhcp_pool1
/interface pptp-server server
set enabled=yes
add address=192.168.0.2/24 interface=WAN1 network=192.168.0.0
add address=192.168.2.2/24 interface=WAN2 network=192.168.2.0
add address=192.168.3.2/24 interface=WAN3 network=192.168.3.0
add address=192.168.4.2/24 interface=WAN4 network=192.168.4.0
add address=10.0.0.1/16 interface=LAN network=10.0.0.0
add address=10.0.0.0/16 dns-server=8.8.8.8,8.8.4.4 gateway=10.0.0.1
/ip firewall mangle
add action=accept chain=prerouting disabled=yes dst-address=\
192.168.0.0-192.168.4.255 in-interface=LAN
add action=mark-connection chain=prerouting connection-mark=no-mark \
dst-address-type=!local in-interface=LAN new-connection-mark=ISP1_conn \
passthrough=yes per-connection-classifier=both-addresses-and-ports:4/0
dst-address-type=!local in-interface=LAN new-connection-mark=ISP2_conn \
passthrough=yes per-connection-classifier=both-addresses-and-ports:4/1
dst-address-type=!local in-interface=LAN new-connection-mark=ISP3_conn \
passthrough=yes per-connection-classifier=both-addresses-and-ports:4/2
dst-address-type=!local in-interface=LAN new-connection-mark=ISP4_conn \
passthrough=yes per-connection-classifier=both-addresses-and-ports:4/3
add action=mark-routing chain=prerouting connection-mark=ISP1_conn \
in-interface=LAN new-routing-mark=to_ISP1
add action=mark-routing chain=prerouting connection-mark=ISP2_conn \
in-interface=LAN new-routing-mark=to_ISP2
add action=mark-routing chain=prerouting connection-mark=ISP3_conn \
in-interface=LAN new-routing-mark=to_ISP3
add action=mark-routing chain=prerouting connection-mark=ISP4_conn \
in-interface=LAN new-routing-mark=to_ISP4
add action=mark-connection chain=prerouting connection-state=new \
in-interface=WAN1 new-connection-mark=ISP1_conn passthrough=no
in-interface=WAN2 new-connection-mark=ISP2_conn passthrough=no
in-interface=WAN3 new-connection-mark=ISP3_conn passthrough=no
in-interface=WAN4 new-connection-mark=ISP4_conn passthrough=no
add action=mark-routing chain=output connection-mark=ISP1_conn \
new-routing-mark=to_ISP1 passthrough=no
add action=mark-routing chain=output connection-mark=ISP2_conn \
new-routing-mark=to_ISP2 passthrough=no
add action=mark-routing chain=output connection-mark=ISP3_conn \
new-routing-mark=to_ISP3 passthrough=no
add action=mark-routing chain=output connection-mark=ISP4_conn \
new-routing-mark=to_ISP4 passthrough=no
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add action=masquerade chain=srcnat out-interface=WAN3
add action=masquerade chain=srcnat out-interface=WAN4
add check-gateway=ping distance=1 gateway=192.168.0.1 routing-mark=to_ISP1
add check-gateway=ping distance=1 gateway=192.168.2.1 routing-mark=to_ISP2
add check-gateway=ping distance=1 gateway=192.168.3.1 routing-mark=to_ISP3
add check-gateway=ping distance=1 gateway=192.168.4.1 routing-mark=to_ISP4
add check-gateway=ping distance=2 gateway=192.168.2.1
add check-gateway=ping distance=3 gateway=192.168.3.1
add check-gateway=ping distance=4 gateway=192.168.4.1
/ppp secret
add local-address=10.0.0.1 name=eslam password=123123 profile=VPN_Profile \
service=pptp
You won’t recieve IP from dhcp server. ROS can’t do such thing. What route do you have on pptp client to reach 10.0.0.0/16? And what IP addresses your LAN devices have?
I receive IP from DHCP server: 10.0.0.2
and about the route, I post all routes I have.
LAN Adress: 10.0.0.0/16
try to ping 10.0.0.211 (DVR)
10.0.0.2 is IP from pool, but it’s not mean dhcp server gave that to you. You using ptp protocol. DHCP server not working that way on Router OS. Do you see an active lease in dhcp-server tab?
This is a routing table from you pptp server(Tik). And I need to see routing table in your device which connects to Tik.
Do you see an active lease in dhcp-server tab? No
This rote print on Tik
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 192.168.0.1 1
1 A S 0.0.0.0/0 192.168.2.1 1
2 A S 0.0.0.0/0 192.168.3.1 1
3 A S 0.0.0.0/0 192.168.4.1 1
4 A S 0.0.0.0/0 192.168.0.1 1
5 S 0.0.0.0/0 192.168.2.1 2
6 S 0.0.0.0/0 192.168.3.1 3
7 S 0.0.0.0/0 192.168.4.1 4
8 ADC 10.0.0.0/16 10.0.0.1 LAN 0
9 ADC 192.168.0.0/24 192.168.0.2 WAN1 0
10 ADC 192.168.2.0/24 192.168.2.2 WAN2 0
11 ADC 192.168.3.0/24 192.168.3.2 WAN3 0
12 ADC 192.168.4.0/24 192.168.4.2 WAN4 0
and this route print from my PC using VPN
C:\Users\eslam>route print
Interface List
16...00 23 24 7e e2 7d ......Intel(R) Ethernet Connection I217-LM
30...........................Mega
9...00 ac 32 ff 06 3d ......VPN Client Adapter - VPN
1...........................Software Loopback Interface 1
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 172.16.0.1 172.16.0.110 4250
0.0.0.0 0.0.0.0 On-link 10.0.0.2 26
10.0.0.2 255.255.255.255 On-link 10.0.0.2 281
41.49.42.38 255.255.255.255 172.16.0.1 172.16.0.110 4251
127.0.0.0 255.0.0.0 On-link 127.0.0.1 4556
127.0.0.1 255.255.255.255 On-link 127.0.0.1 4556
127.255.255.255 255.255.255.255 On-link 127.0.0.1 4556
172.16.0.0 255.255.252.0 On-link 172.16.0.110 4506
172.16.0.110 255.255.255.255 On-link 172.16.0.110 4506
172.16.3.255 255.255.255.255 On-link 172.16.0.110 4506
224.0.0.0 240.0.0.0 On-link 127.0.0.1 4556
224.0.0.0 240.0.0.0 On-link 172.16.0.110 4506
224.0.0.0 240.0.0.0 On-link 10.0.0.2 26
255.255.255.255 255.255.255.255 On-link 127.0.0.1 4556
255.255.255.255 255.255.255.255 On-link 172.16.0.110 4506
255.255.255.255 255.255.255.255 On-link 10.0.0.2 281
Persistent Routes:
None
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
1 331 ::1/128 On-link
16 281 fe80::/64 On-link
16 281 fe80::2889:aa16:c350:989d/128
On-link
1 331 ff00::/8 On-link
16 281 ff00::/8 On-link
Persistent Routes:
None
Do traceroute from PC to 8.8.8.8.
C:\Users\eslam>tracert 8.8.8.8
Tracing route to google-public-dns-a.google.com [8.8.8.8]
over a maximum of 30 hops:
1 37 ms 30 ms 32 ms 10.0.0.1
2 29 ms 30 ms 29 ms 192.168.0.1
3 84 ms * 87 ms 10.45.5.65
4 153 ms 129 ms 75 ms 10.36.13.65
5 86 ms 90 ms 94 ms 10.37.89.249
6 72 ms 96 ms 105 ms 10.36.11.14
7 55 ms 54 ms 52 ms 10.37.87.158
8 52 ms 56 ms 52 ms 10.37.32.170
9 53 ms 54 ms 60 ms host-163.121.219.170.tedata.net
10 54 ms 89 ms 58 ms 10.37.32.173
11 50 ms 51 ms 73 ms 10.37.87.145
12 87 ms 73 ms 71 ms 10.37.85.101
13 112 ms 102 ms 99 ms 72.14.205.68
14 146 ms 118 ms 115 ms 108.170.252.225
15 * 110 ms 168 ms 216.239.35.197
16 80 ms 83 ms 80 ms google-public-dns-a.google.com [8.8.8.8]
Trace complete.
Trace complete.
Okay, seems you going through the tunnel. Look for firewall settings on 10.0.0.211 or Tik filter for forwarding. Try to ping another device in home LAN.
In LAN working
and from Tik working too..
I mean ping from vpn PC another LAN device. Aka 10.0.0.145 or whatever you have.
He done it
I cant ping from VPN to any device in LAN
but I can ping from VPN to routers (IN WANs) WAN1, WAN2,WAN3,WAN4 (192.168.0.1,192.168.2.1,192.168.3.1,192.168.4.1)
Can LAN device ping vpn PC? 10.0.0.2.
Your logic is more adapted for L2 VPN. And you have here L3 vpn with ppp base. You already have LAN on Tik with 10.0.0.0/16. Make in ppp profile local address 10.10.10.1 and remote from pool 10.10.10.2-10.10.10.255.
Show traceroute from 10.10.10.2 to 10.0.0.211.
Tracing route to 10.0.0.211 over a maximum of 30 hops
1 29 ms 29 ms 30 ms 10.0.0.1
2 * * * Request timed out.
3 * * * Request timed out.
