Cant ping to sip provider from freepbx
Hi, I installed freepbx in esxi vm with the ip address of 192.168.200.253 and the gateway is 192.168.200.254 in mikrotik router and I have an other interface with the ip address of 10.177.2.201 its the way to sip proivder and the sip proivder ip address is 10.150.28.252 and media address is 10.150.28.253. my problem is that I can ping both ip addresses 10.150.28.252 and 10.150.28.253 from my mikrotik router but I cant ping these two ip from freepbx. I created the route in freeobx and still it dose not work.
From how badly and vaguely you described the problem,
I think you need a consultant to check the configuration of everything, not just RouterOS…
And also the “bold mess” you done… ([b] )
