Can't route vlan
Hi guys.
I'm new to the Mikrotik world and I need your help.
I'm installing RouterOS on a DELL server (PowerEdge T610) connected to an Enterasys C3 Switch. The problem is: if I use untagged vlan, it works fine. When I use tagged vlan, I just can't ping anything on the other side
From Mikrotik I ping 192.168.64.1, but I can't ping 192.168.128.1
Here the Mikrotik commands:
add name=bridge_14
add name=bridge_18
/interface vlan
add interface=ether3 name=ether3_vl18 vlan-id=18
add bridge=bridge_14 interface=ether3
add bridge=bridge_18 interface=ether3_vl18
add address=192.168.64.252/20 interface=bridge_14 network=192.168.64.0
add address=192.168.128.3/20 interface=bridge_18 network=192.168.128.0
[admin@MikroTik] > /ip route pr
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 X S 0.0.0.0/0 192.168.64.1 1
1 A S 192.168.0.0/20 192.168.64.1 1
2 ADC 192.168.64.0/20 192.168.64.252 bridge_14 0
3 ADC 192.168.128.0/20 192.168.128.3 bridge_18 0
And the C3 vlan configuration:
acursw01(su)->show vlan portinfo
Port VLAN Ingress Egress
Filter Vlan
ge.1.9 14 N untagged: 14
ge.1.10 1 N untagged: 18
ge.1.24 14 N untagged: 14 tagged: 10,11,12,13,15,16,17,18,20,21,22,23,24,25,26,29,41,101,150,191,193,200,1911
This should work. If I replace the Dell Server T610 with a simple PC, with just one ethernet card, it works! I believe it may be a lost configuration on Dell hardware. Does anyone have experience using it?
The way you configured VLANs on Dell is calling for trouble. Read through this tutorial and do it in modern way.
I think you need to specify the tagged and untagged ports
Try this:
/interface bridge vlan
add bridge=bridge_14 untagged=ether3 vlan-ids=14
add bridge=bridge_18 tagged=ether3 vlan-ids=18
also try activating VLAN filtering
set bridge_14 vlan-filtering=yes
set bridge_18 vlan-filtering=yes
