Most users in this forum are experiencing the same issue.
A don’t say that all cAP ACs are bad, I think this is a great product.
But I ordered 2, tried every wireless config possibility, and can’t get normal throughput.
If someone has a working wireless config with 6.42rc, please post it.
I’ve got pretty decent results on my iPhone X over cAP AC. What is interesting for me, my iPhone is connected on 433Mbps link speed. Why not 866 if I got both chains enabled ?
I had a load of disconnects / reconnects from a netatmo camera. I then check ked the firmware and realised that I could not update the firmware, or when I did, it would not stick. I eventually got it accept the latest RC firmware by using the tik app. If you are experiencing disconnects make sure your CAP AC device is actually using the most recent firmware. Once I got this done the disconnect / reconnect issue has gone.
Anyways, I still bought the cap ac. I think I made a very big mistake. I put the Cap ac up on the ceiling. And right now I’m sitting in the same room about 4 meters from the cap ac. And I got the results
any advice, return???
Different room 1,5 metres away
Have you actually tried pushing traffic through it? Most devices won’t try to negotiate higher rates until it’s needed. Simply associating and looking at speed often provides misleading results.
I didn’t see this thread before and was just hungry for the hap ac² and the cap ac by looking at the specs. they arrived yesterday.
for me the signal strength improved a bit on both devices. however, i confirm from my side that the throughput is much slower.
i am not using yet the RC firmware. i have the 6.41.4 running.
I really hope this will be solved very soon. I don’t want to be forced to return the devices, since the specs and price were exactly what my wet dreams were about the whole last year.
