I have similiar experience. Speedtest.net shows ~180mbps gradually settling on ~80mbps or worse; iperf3 shows even less impressive numbers
I did some comparisons between cAP AC and my good old hAP AC.
Test conditions/parameters:
802.11an two chains (My Lenovo T420 laptop doesn’t have 802.11ac)
hAP AC was running 6.40.1; cAP AC was running 6.40.6
Both hAP AC and cAP AC were running virtually the same wireless interface settings:
On cAP AC:
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee country=lithuania disabled=no distance=indoors frequency=auto mode=ap-bridge rx-chains=0,1 \
security-profile=profile1 ssid=CAP5 tx-chains=0,1 wireless-protocol=802.11
On hAP AC:
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee country=lithuania disabled=no frequency=auto \
mode=ap-bridge security-profile=profile_lukoramu ssid=MTLR wireless-protocol=802.11
Both chose the same frequency (5180MHz). I kept only one AP turned on at the same time, so no interference between them.
Wireless registration stats on cAP AC:
0 interface=wlan2 mac-address=8C:70:5A:79:C2:C8 ap=no wds=no bridge=no rx-rate="300Mbps-40MHz/2S/SGI" tx-rate="270Mbps-40MHz/2S" packets=346474,437622
bytes=372188772,541051178 frames=346474,437626 frame-bytes=372881728,538425898 hw-frames=385547,440278 hw-frame-bytes=425802032,556703304 tx-frames-timed-out=0
uptime=9m22s last-activity=0ms signal-strength=-58dBm@HT40-7 signal-to-noise=42dB signal-strength-ch0=-64dBm signal-strength-ch1=-60dBm
strength-at-rates=-55dBm@6Mbps 1s870ms,-62dBm@12Mbps 8m26s160ms,-52dBm@48Mbps 5m5s810ms,-50dBm@54Mbps 9m21s820ms,-57dBm@HT40-4 9m20s790ms,-54dBm@HT40-5 6m54s360ms,-
55dBm@HT40-6 4m50s810ms,-58dBm@HT40-7 0ms
tx-ccq=98% p-throughput=234464 last-ip=192.168.198.194 802.1x-port-enabled=yes authentication-type=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm
management-protection=no wmm-enabled=yes tx-rate-set="OFDM:6-54 BW:1x-2x SGI:1x-2x HT:0-15"
Wireless registration stats on hAP AC:
0 interface=wlan2 mac-address=8C:70:5A:79:C2:C8 ap=no wds=no bridge=no rx-rate="300Mbps-40MHz/2S/SGI" tx-rate="54Mbps" packets=729,874 bytes=618384,118750 frames=729,876
frame-bytes=619838,113744 hw-frames=753,1046 hw-frame-bytes=664555,152832 tx-frames-timed-out=0 uptime=35s last-activity=0ms signal-strength=-46dBm@6Mbps
signal-to-noise=58dB signal-strength-ch0=-49dBm signal-strength-ch1=-50dBm signal-strength-ch2=-59dBm
strength-at-rates=-46dBm@6Mbps 70ms,-45dBm@54Mbps 35s,-50dBm@HT40-4 34s70ms,-50dBm@HT40-5 33s970ms,-50dBm@HT40-6 33s750ms,-51dBm@HT40-7 0ms tx-ccq=90%
p-throughput=30502 distance=1 last-ip=192.168.198.194 802.1x-port-enabled=yes authentication-type=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm
TCP upload results:
cAP AC:
C:\Users\lukoramu\Documents\orphan\iperf>iperf3 -c 84.32.123.242
Connecting to host 84.32.123.242, port 5201
[ 4] local 192.168.198.194 port 52515 connected to 84.32.123.242 port 5201
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 6.38 MBytes 53.2 Mbits/sec
[ 4] 1.00-2.00 sec 19.2 MBytes 162 Mbits/sec
[ 4] 2.00-3.01 sec 18.5 MBytes 154 Mbits/sec
[ 4] 3.01-4.01 sec 17.5 MBytes 147 Mbits/sec
[ 4] 4.01-5.01 sec 13.9 MBytes 116 Mbits/sec
[ 4] 5.01-6.01 sec 0.00 Bytes 0.00 bits/sec
[ 4] 6.01-7.01 sec 0.00 Bytes 0.00 bits/sec
[ 4] 7.01-8.01 sec 0.00 Bytes 0.00 bits/sec
[ 4] 8.01-9.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 9.00-10.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 0.00-10.00 sec 75.5 MBytes 63.3 Mbits/sec sender
[ 4] 0.00-10.00 sec 75.5 MBytes 63.3 Mbits/sec receiver
hAP AC:
[ 4] local 192.168.198.194 port 52581 connected to 84.32.123.242 port 5201
[ 4] 0.00-1.01 sec 20.6 MBytes 172 Mbits/sec
[ 4] 1.01-2.00 sec 20.1 MBytes 170 Mbits/sec
[ 4] 2.00-3.01 sec 20.5 MBytes 171 Mbits/sec
[ 4] 3.01-4.01 sec 20.8 MBytes 174 Mbits/sec
[ 4] 4.01-5.01 sec 20.5 MBytes 171 Mbits/sec
[ 4] 5.01-6.01 sec 20.4 MBytes 171 Mbits/sec
[ 4] 6.01-7.01 sec 20.6 MBytes 173 Mbits/sec
[ 4] 7.01-8.01 sec 20.1 MBytes 169 Mbits/sec
[ 4] 8.01-9.01 sec 19.9 MBytes 166 Mbits/sec
[ 4] 9.01-10.01 sec 20.4 MBytes 170 Mbits/sec
[ 4] 0.00-10.01 sec 204 MBytes 171 Mbits/sec sender
[ 4] 0.00-10.01 sec 204 MBytes 171 Mbits/sec receiver
TCP download results:
cAP AC:
C:\Users\lukoramu\Documents\orphan\iperf>iperf3 -c 84.32.123.242 -R
Reverse mode, remote host 84.32.123.242 is sending
[ 4] local 192.168.198.194 port 52521 connected to 84.32.123.242 port 5201
[ 4] 0.00-1.01 sec 1.10 MBytes 9.18 Mbits/sec
[ 4] 1.01-2.01 sec 0.00 Bytes 0.00 bits/sec
[ 4] 2.01-3.01 sec 0.00 Bytes 0.00 bits/sec
[ 4] 3.01-4.01 sec 0.00 Bytes 0.00 bits/sec
[ 4] 4.01-5.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 5.00-6.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 6.00-7.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 7.00-8.00 sec 2.48 MBytes 20.8 Mbits/sec
[ 4] 8.00-9.01 sec 0.00 Bytes 0.00 bits/sec
[ 4] 9.01-10.01 sec 0.00 Bytes 0.00 bits/sec
[ ID] Interval Transfer Bandwidth Retr
[ 4] 0.00-10.01 sec 3.79 MBytes 3.18 Mbits/sec 113 sender
[ 4] 0.00-10.01 sec 3.71 MBytes 3.11 Mbits/sec receiver
hAP AC:
[ 4] local 192.168.198.194 port 52587 connected to 84.32.123.242 port 5201
[ 4] 0.00-1.00 sec 20.3 MBytes 170 Mbits/sec
[ 4] 1.00-2.00 sec 20.1 MBytes 169 Mbits/sec
[ 4] 2.00-3.00 sec 20.8 MBytes 174 Mbits/sec
[ 4] 3.00-4.00 sec 20.5 MBytes 171 Mbits/sec
[ 4] 4.00-5.01 sec 20.6 MBytes 172 Mbits/sec
[ 4] 5.01-6.01 sec 20.2 MBytes 169 Mbits/sec
[ 4] 6.01-7.01 sec 20.8 MBytes 174 Mbits/sec
[ 4] 7.01-8.00 sec 20.8 MBytes 176 Mbits/sec
[ 4] 8.00-9.00 sec 20.7 MBytes 174 Mbits/sec
[ 4] 9.00-10.00 sec 20.9 MBytes 175 Mbits/sec
[ 4] 0.00-10.00 sec 206 MBytes 173 Mbits/sec 0 sender
[ 4] 0.00-10.00 sec 206 MBytes 173 Mbits/sec receiver
Thoughts? Ideas?
Maybe it’s a compatibility issue?.. Tomorrow I will do the test with a newer laptop, which has an AC card..
P.S. I noticed a big difference in Tx/Rx signals too (see above)
