cAP ax no ip for wireless clients
I have a problem with my hEX router and cAp ax access point. Or I believe the problem is with the cAP configuration. I have done the configuration according to the wiki pages, here and here.
The hEX gives an ip and internet access to clients, eg. my laptop or the cAP when connecting via ethernet so I don’t believe my configuration is too wrong as I can get an internet connection. I have set the cAP’s ip as static. When I try to connect to the cAP, with my phone for example, it errors out and says it can’t get an ip address from the access point.
I don’t think the access point should have it’s own DHCP server as the router already has one. I suspect I have overlooked something and the cAP doesn’t communicate with the hEX properly to get an ip lease from the hEX for wireless clients. I hope I have explained my problem clearly, sorry if it’s too long. Here’s my configuration for my cAP ax:
# 2023-08-04 18:28:45 by RouterOS 7.10.2
# software id = **ELIDED**
# model = cAPGi-5HaxD2HaxD
# serial number = **ELIDED**
/interface wifiwave2
set [ find default-name=wifi1 ] configuration.country=Latvia .mode=ap .ssid=**ELIDED** disabled=no security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] configuration.country=Latvia .mode=ap .ssid= **ELIDED** disabled=no security.authentication-types=wpa2-psk,wpa3-psk
add name=WAN
add name=LAN
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk disable-pmkid=yes disabled=no \
    management-protection=allowed name=sec1
add interface=ether1 list=WAN
add list=LAN
add address=192.168.88.253/24 interface=ether2 network=192.168.88.0
/ip dhcp-client
/system clock
set time-zone-name=Europe/Helsinki
/system note
set show-at-login=no
And my hEX config:
# 2023-08-04 18:31:35 by RouterOS 7.10.2
# model = RB750Gr3
add name=local
add name=listBridge
/ip hotspot profile
add name=dhcp_pool0 ranges=192.168.88.2-192.168.88.254
add address-pool=dhcp_pool0 interface=local name=dhcp1
/port
set 0 name=serial0
add bridge=local interface=ether2
set discover-interface-list=listBridge
add interface=local list=listBridge
add address=192.168.88.1/24 interface=local network=192.168.88.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.254 client-id=1:48:a9:8a:9c:38:b8 mac-address=\
    48:A9:8A:9C:38:B8 server=dhcp1
add address=192.168.88.253 client-id=1:48:a9:8a:cc:73:be mac-address=\
    48:A9:8A:CC:73:BE server=dhcp1
add address=192.168.88.0/24 dns-server=9.9.9.9 gateway=192.168.88.1
set servers=9.9.9.9
add action=accept chain=input comment="accept established,related" \
add action=drop chain=input connection-state=invalid
add action=drop chain=input in-interface=ether1
add action=fasttrack-connection chain=forward connection-state=\
    established,related hw-offload=yes
add action=accept chain=forward connection-state=established,related
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=2200
set api disabled=yes
set winbox address=192.168.88.0/24
/ip ssh
set strong-crypto=yes
/system clock
/system identity
set name="MikroTik hEX"
/system note
/tool bandwidth-server
set enabled=no
/tool mac-server
set allowed-interface-list=listBridge
/tool mac-server mac-winbox
Surely that’s not the complete config of cap AX ?
Where is the bridge ?
Which ports are assigned to it ?
  • Create a bridge
  • Assign at least ether1 to it, ether2 I leave up to you
  • Also add wireless interfaces.
  • DHCP client on bridge.
Thank you, that did the trick. That was actually the complete config at the time of posting. I previously tried creating a creating a bridge but only added ether1 as a port to it as wifi1 and wifi2 were greyed out. I assumed this meant they were not supposed to be added to the bridge but later learned this meant they were disabled because no wireless clients were connected at the time.
