I have a cAP ax being operated from the supplied 48v power supply. Also have a device that supports standard PoE 802.3af Mode-A, which requires only four wires of a network cable (it works fine with a TL-POE150S V3 Injector).
Is it possible to power this device from the cAP ax PoE-out port?
In theory a 802.3af compliant device (PD or Powered Device) should be compatible with both Mode A and Mode B.
See: http://forum.mikrotik.com/t/hex-poe-48v-802-3af-at-only-b/127845/1
The 4 unused cable are not unused in a 1 GB connection anyway.
The device providing power (PSE or Power Source Equipment) can then be either mode A or mode B, the difference with passive is that the 802.3a compliant device “interrogates” the other end by “probing” it with - initially - a very low voltage and expects a reply before switching on the 48V or so power, so called PoE negotiation.
The (passive) Mikrotik has only a simpler check for resistance on the other side if auto-on: https://help.mikrotik.com/docs/display/ROS/PoE-Out
which may (or may not) be enough in the PD to switch on the power.
You can still force it on with forced-on.
Then the PD may either “accept” the 48V or so volts or - because there has not been a previous PoE negotiation - I believe that different devices may have different implementations.
In some cases a splitter/converter and powering the device from the DC jack may be needed.
Do you need/want a 10/100 or a 1000 Mb connection between the two devices? ← if needed, splitting the power off a Mode B 10/100 connection can be a DIY job besides using common splitters (otherwise a GB splitter is needed)
Can you post the exact make/model of the powered device? ← Maybe some member have already some experience with the specific device
DoorBird D1101V IP Video Door Station. The connection is via an RJ45 socket to 4-wires orange+white (T+), orange (T-), green+white (R+), green (R-). I suspect, but haven’t confirmed, that these correspond with pins 1,2,3,6 and that pins 4,5,7,8 are unconnected (high resistance).
Rebooted the cAP ax with nothing on ether2. Attached the D1101V. No PoE entries in the log. The bell push didn’t light up suggesting it doesn’t have power. This from the terminal:
The fact that they specify “Mode A” makes me think that the device is not fully 802.3af compliant.
And it accepts the 48V on the PoE only (normal power is an “odd” 15V).
@infabo
The point remains that a PD device is either 802.3af compliant (and thus accepts both mode A and mode B) or it isn’t, “802.3af Mode A” is a non-standard.
@JohnConnett
But then you will need to run a couple additional wires from the DIN rail 15V power supply to the D1101V Door Station.
