cap ax with old capsman on wi-fi ac
Hello, can I turn off wifi 6 on cap ax and use wi-fi ac like old devices?
And connect cap ax to to old capsman with wi-fi ac ?
No. Ax devices require wifiwave2 driver, which in turn is not compatible with legacy capsman.
Well, technically you can disable 802.11ax support on wifiwave2 driven APs, but I guess this isn’t what you’re after.
Can i disable 802.11ax driver and use 802.11ac driver (on cap_ax) as Cap_ac device ? How i can did it ?
Impossible.
