Cap Lite RBcAPL-2nD slow wifi speed
I am having issues with Cap Lite RBcAPL-2nD, set to CAP mode, controlled by CAPSMAN on RB750Gr3. My internet input speed to the RB750Gr3 is 150/10 Mbit. The Cap Lite is connected directly to the RB750Gr3. No matter what frequency or band I use, I never get more then 50Mbit over wifi from the Cap Lite.
Manufacturer says, it should do 300Mbit over wifi. I know it wont in CAP mode since the input is over LAN which is only 100Mbit, but still 50Mbit is much lesser then I would expect. I would be happy with something around 90Mbit.
Any uggestions?
here is RB750Gr3 CAPSMAN config:
mar/11/2022 22:15:18 by RouterOS 6.49.4
software id = BH0U-LLIT
model = RB750Gr3
serial number = CC210FEEF5C1
/caps-man channel
add band=2ghz-onlyn control-channel-width=20mhz extension-channel=disabled
frequency=2472 name="HOME 11"
add admin-mac=DC:2C:6E:11:16:DF auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=AC:22:05:9C:62:C6 name=
ether1-WAN
set [ find default-name=ether2 ] name=ether2-MARIOS
set [ find default-name=ether3 ] name=ether3-GREG
set [ find default-name=ether5 ] name=ether5-CAPLITE
/caps-man datapath
add arp=enabled bridge=bridge client-to-client-forwarding=no
local-forwarding=no name=datapath1
/caps-man rates
add basic=54Mbps name=rate1 supported=54Mbps
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=HOME passphrase=
Tojejedno1234
/caps-man configuration
add channel="HOME 11" country="czech republic" datapath=datapath1
datapath.bridge=bridge distance=indoors installation=indoor mode=ap name=
"CFG HOME" rates=rate1 rx-chains=0,1,2 security=HOME
security.authentication-types=wpa2-psk security.encryption=aes-ccm
security.passphrase=Tojejedno1234 ssid=MikroTik-99999 tx-chains=0,1,2
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=
profile1 supplicant-identity="" wpa2-pre-shared-key=Hovno1234
/ip firewall layer7-protocol
add name=Steam regexp="^..+\.(steam|valve|steampowered|steamcommunity|steamga
mes|steamusercontent|steamcontent|steamstatic).*$"
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/queue simple
add max-limit=8M/150M name=Global priority=1/1 target=192.168.88.0/24
add limit-at=8M/150M max-limit=8M/150M name=Steam packet-marks=steam-pk
parent=Global priority=1/1 queue=default/default target=192.168.88.0/24
add limit-at=5M/130M max-limit=5M/130M name=Browsing packet-marks=http-pk
parent=Global priority=5/5 queue=default/default target=192.168.88.0/24
add limit-at=5M/130M max-limit=5M/130M name=Other packet-marks=other-pk
parent=Global queue=default/default target=192.168.88.0/24
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge
/caps-man provisioning
add action=create-dynamic-enabled master-configuration="CFG HOME"
name-format=prefix
add bridge=bridge comment=defconf interface=ether2-MARIOS
add bridge=bridge comment=defconf interface=ether3-GREG
add bridge=bridge comment=defconf interface=ether5-CAPLITE
add comment=defconf interface=ether1-WAN list=WAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
add address=78.45.88.44/24 interface=ether1-WAN network=78.45.88.0
/ip dhcp-client
set allow-remote-requests=yes servers=86.49.5.221,86.49.5.222
/ip dns static
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=fasttrack-connection chain=forward comment="fasttrack Steam"
connection-mark=steam-conn disabled=yes
/ip firewall mangle
add action=mark-connection chain=forward comment="Steam UDP Ports"
connection-mark="" new-connection-mark=steam-conn passthrough=yes port=
7777-7779,27900 protocol=udp
add action=mark-connection chain=forward comment="Steam TCP Ports" dst-port=
7777,8080,8777,9777,27900,9405,9505 new-connection-mark=steam-conn
passthrough=yes protocol=tcp
add action=mark-connection chain=forward comment="Steam L7" layer7-protocol=
Steam new-connection-mark=steam-conn passthrough=yes protocol=tcp
add action=mark-connection chain=forward comment="Steam https" dst-port=443
new-connection-mark=steam-conn passthrough=yes protocol=tcp tls-host=
steam
add action=mark-packet chain=forward comment=all-steam-pk connection-mark=
steam-conn new-packet-mark=steam-pk passthrough=no
add action=mark-connection chain=forward comment="http-conn 80" dst-port=80
new-connection-mark=http-conn passthrough=yes protocol=tcp
add action=mark-connection chain=forward comment="http-conn 443" dst-port=443
add action=mark-packet chain=forward comment=http-pk connection-mark=
http-conn new-packet-mark=http-pk passthrough=no
add action=mark-connection chain=forward comment=other-conn
new-connection-mark=other-conn passthrough=yes
add action=masquerade chain=srcnat comment="defconf: masquerade"
add distance=1 gateway=78.45.88.1
/system clock
set time-zone-name=Europe/Prague
/system identity
set name="MikroTik HEX"
/system ntp client
set enabled=yes primary-ntp=80.79.25.111 secondary-ntp=162.159.200.123
/system ntp server
set broadcast=yes enabled=yes
/tool mac-server
/tool mac-server mac-winbox
You can change channel-width from 20Mhz to 20/40Mhz, that should give a boost to your throughput, but as cAP lite has only a 100Mbps ether port, you won’t be getting much more.
That and:
  • band selection: use 2Ghz N only if possible for your client devices (it’s covered)
  • Data rates: increase supported rate to at least 18mbps (if your client devices accept it !! You may have to play a bit to see how far you can go) - I see you have 54Mb as basic and supported rate. It doesn’t cause any problems for your client devices ?
  • Data rates: supported rates, remove everything lower then 18mbps (see previous remark, both go together)
  • disable WPS mode (I don’t have the device in front of me but as far as I know Cap Lite does not have such a button, so disable the feature, especially if not being used), it takes away airtime
  • scan surrounding frequencies/channels ! See if there is a channel where you can be “alone”. Difficult when using 2.4Ghz but maybe some channels are less crowded then others ? Even one single other AP using the same channel, will take down your performance. It’s only when you’re completely alone that you can get the most out of it. And co-existence (same channels being used) is better then overlap !! (overlap = e.g. one AP with 40Mh on 6, another with 40Mhz on 7)
    It could also mean being alone using 20Mhz might be better then using 20/40 when having overlap.
    Experiment.
  • don’t use capsman forwarding unless really needed (ie: change local-forwarding to yes). It requires encryption of part of the communication (headers) and decryption again at the caps controller. Waste of time and resources.
On mAP or mAP Lite (same HW config ?) I can get close to 70 Mbps using these modifications (but there is always one other AP in the neighborhood at home, I’m never alone on whatever channel I use). I’d say that’s more then enough for those little buggers on 2.4Ghz.
Where is config of cap lite ? Or is it only cap-mode and nothing else ?
hello, thank for you reply, as you can see in my configuration,
  • I use 2GHz-N only
    -reagrding data rates, none of my connected clients have problem with 54Mbit
    -I tried to disable WPS, but I found this optoin only under CAP LITE wireles settings, and when tried to change, it said its controlled by the CAPSMAN. In CAPSMAN i didnt find this option
    -I did scan all channels around me and 2472 was the only one, which wasnt used by any other router, so i am the only one around using this frequency
    -I dont use Local forwarding on CAPSMAN
    -CAP LITE is iny CAP mode, nothing else, no firewal, no nothing, everything is controlled by the CAPSMAN and still getting maximum of 52Mbits over wifi
CAP LITE configuration
mar/14/2022 14:31:52 by RouterOS 6.49.4
software id = 2TWM-RWF3
model = RouterBOARD cAP L-2nD
serial number = 792E095518A9
add admin-mac=B8:69:F4:2F:4A:E8 auto-mac=no comment=defconf name=bridgeLocal
/interface wireless
managed by CAPsMAN
channel: 2472/20/gn(18dBm), SSID: MikroTik-99999, CAPsMAN forwarding
set [ find default-name=wlan1 ] band=2ghz-onlyn country="czech republic"
frequency=2472 installation=indoor mode=ap-bridge ssid=MikroTik-99999
wireless-protocol=802.11
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=
Tojejedno1234 wpa2-pre-shared-key=Tojejedno1234
add name=dhcp ranges=192.168.99.2-192.168.99.10
add address-pool=dhcp interface=wlan1 name=dhcp1
/interface bridge filter
add action=drop chain=input dst-port=68 in-interface=ether1 ip-protocol=udp
mac-protocol=ip
add bridge=bridgeLocal comment=defconf hw=no interface=ether1
add bridge=bridgeLocal interface=wlan1
add interface=ether1 list=WAN
add interface=wlan1 list=LAN
/interface wireless cap
set discovery-interfaces=ether1 enabled=yes interfaces=wlan1
add address=192.168.88.33/24 disabled=yes interface=ether1 network=
192.168.88.0
add address=192.168.88.33/24 interface=wlan1 network=192.168.88.0
/ip dhcp-client
add interface=bridgeLocal
add address=0.0.0.0/24 gateway=0.0.0.0 netmask=24
add address=192.168.88.0/24 gateway=192.168.88.33 netmask=24
set servers=192.168.88.1
add action=masquerade chain=srcnat disabled=yes out-interface-list=WAN
add distance=1 gateway=192.168.88.1
/system clock
/system identity
set name="CAP LITE"
/system ntp client
set enabled=yes primary-ntp=192.168.88.1
What's this ?
/interface wireless
managed by CAPsMAN
You're not using local forwarding ? You should. Unless you have a specific reason not to ?
And set on capsman the bandwidth to 20/40, see what that gives.
Is there a reason why you use capsman ? A lot of devices, perhaps ?
If only a limited number, do the settings on the caps devices directly. Much easier.
What's this ?
/interface wireless
managed by CAPsMAN
eeeh, what yo you mean what is this? this is that the CAP is controlled by the CAPSMAN
-I tried to use local forwarding, but it didnt have any impact on the wifi speed
-the reason is, that i like this option, its at my home, so its only one device, anyway I tried to use CAP LITE as a router, and the results were the very same...
Wifi speed will never be impacted on itself but speed between Cap Lite and Hex WILL be impacted as explained above.
You don’t need to use CAP as a router. Just use it as a simple access point.
-I didnt notice any impact on the speeds between capsman and caps if local forwarding enabled/disabled
-yes i meant using it as an AP, same results
So i guess it is not solved…
If you remove the CAP from the Capsman, do you see any improvement in the Speeds ?
oh my, now i did try to put CAP LITE in Home AP mode, Ive dissabled WPS and now Im getting 62,6Mbit over wifi, which is little improvement…even upload is now 11,8Mbit, which is strange since my internet connection limit is 150/10Mbit :slight_smile:
As you can see the problem is not the CapsMAN.
Don’t expect to reach the full bandwidth of 150 Mbps…
Other than that remove Band b, set Bands to g/n only… Set channel width to 20/40 XX and select a less crowded frequency.
Then test again…
