I need to setup a Mikrotik called “TV” (this replaces the Linksys in the diagram above) that has iptv (already untagged 600) and vlan 592 (bridge) incoming on ether1 from this configuration called “Uptown”. On ether2 (port 2, not port 4 in the above diagram) I want to relay iptv to the tv box (aka hypptv).
Next I want to untag 592 to the bridge and have the “TV” Mikrotik by the tv basically setup in CAP mode, so it can be controlled by Capsman on the “Uptown” Mikrotik.
There could be a simpler setup by not sending untagged 600 down ether5, but I prefer this setup because we want to be able to remove the “TV” Mikrotik in the case it fails and plug the cable that comes from “Uptown”'s ether5 directly into the hypptv, if the need arose.
Now I am trying to figure out what I need to change on a typical CAP mode configuration. I guess I need
/ip dhcp-client add comment=defconf dhcp-options=hostname,clientid disabled=no interface=bridgeLocal
But I am not sure how to untag 592 on all ports/interfaces (bridgeLocal) except port 2, which is designated for the hypptv. Any tips?
