a friend of mine gave me a cAP XL AX which seems to be bricked. He said, he only changed configuration but a a certain point in time, he could no longer reach the AP. As I had very good experience in the past with the resuscitability of Mikrotik devices, I gave it a shot. However, I am running out of ideas and seek for help.
Interesting thing first is, that the AP seems never to negotiate more than 100MBit/s, even though the other side is capable of more.
What I tried so far unsuccessfully:
Connecting via WinBox via L2 (MAC-Address). The AP shows up in the Neighbors list (confirmed LLDP with Wireshark) Result: Faild login caused by unsuccessfull retransmissions
Connecting via WinBox via IPv6 (link-local). The AP shows up in the Neighbors list Result: TCP-Retransmissions (seen in Wireshark) -> WinBox showes refuses on wrong credentials, but never get beyond logging in with right ones
Re-installation with NetInstall on Linux and following command: sudo ./netinstall-cli -r -b -v -i ens1 -a 192.168.88.3 ./routeros-7.21.4-arm64.npk
I pressed and hold the RESET button next to the Eth-Ports for at least 60 seconds Result: DHCP requests and DHCP offers seen in wireshark, NetInstall showes the same, and ARM64 as architecture, but installation never starts.
Using a well-setup and productive cAP manager and setting the AP via the RESET button next to the Eth-Ports to the corresponding mode. Result: AP never showing up
Are you used to linux? I setup my RB750 with RouterBoot dhcp instead of RouterBoot bootp, and got it to work in a different way than standard, I know there is a python implementation thats support dhcp of netinstall that uses similar functions that you can probably try, here are links to my attempt and to the python implementation.
And like allways do you use the correct ethernet port like the port 1 ?
