I have a cAP XL configured as a bridge, connected to a router via another switch. The router is the DHCP server, and the cAP has a static IP configured, in the same subnet.
I cannot connect to the cAP’s webfig interface with a browser, nor with Winbox via it’s IP. It only works from Winbox with the MAC address.
It responds to pings though. And when I ping it, ARP is resolving the right MAC, so I’m guessing it’s not an address conflict.
What am I missing here?
This is the output of /export hide-sensitive compact:
[admin@MikroTik cAP XL ac] > /export hide-sensitive compact
# jan/16/1970 20:09:44 by RouterOS 6.49.7
# software id = BBL3-MUR9
# model = RBcAPGi-5acD2nD
# serial number = HDK08******
add admin-mac=48:A9:8A:25:56:85 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk group-ciphers=tkip,aes-ccm mode=dynamic-keys name=auth supplicant-identity="" \
unicast-ciphers=tkip,aes-ccm
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=israel disabled=no distance=indoors \
frequency=2442 installation=indoor mode=ap-bridge security-profile=auth ssid="Net 2.4" wireless-protocol=\
802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=israel disabled=no distance=indoors \
installation=indoor mode=ap-bridge security-profile=auth ssid="Net 5" wireless-protocol=802.11
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
/queue interface
set wlan1 queue=only-hardware-queue
set wlan2 queue=only-hardware-queue
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=ether1
add comment=defconf interface=ether1 list=LAN
add interface=ether2 list=LAN
add interface=wlan2 list=LAN
add interface=wlan1 list=LAN
add disabled=yes
add address=192.168.88.2/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf interface=bridge
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.2 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
/system identity
set name="MikroTik cAP XL ac"
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
\n :if ([system leds settings get all-leds-off] = \"never\") do={\r\
\n /system leds settings set all-leds-off=immediate \r\
\n } else={\r\
\n /system leds settings set all-leds-off=never \r\
\n }\r\
\n "
/tool mac-server
/tool mac-server mac-winbox
