CAPsMAN basis settings Winbox 4.4
I NEVER encourage a "crutch" until the fundamentals are fully understood. It's just too problem prone . . . .
This appears to be yet another case of a user doing much more than needed, and wrapping things around the axle. Just because there is a setting available, doesn't mean that you need to use it . . .
YMMV
jaclaz: That's sample is fill with VLAN without asking. Useless because what I add the parameters (1 router with 1 ap) is fill up a lot of hallucinated stuff. VLAN for guest? Who ask? :slight_smile: The whole bridge vlan interface is shift the setup...
I try to step by step (line by line) crop that instructions the important part, but not working, and my eyes is blow up to search in the GUI the content what the CLI show.
I never understand why make a company GUI if every topic is CLI focused? Check youtube and every guy is show different locations of the settings. (and different revisions):smiley:
Oh btw, I try a old LTE redundant modem setup (config) backup (already made by myself a script to make a USB external LTE backup), but of course not working this time, not boot the router. Every issue needed a hard reset. :smiley:
The whole setup is absolute complicated.
Ethernet interface connected to a bridge (one bridge only hardware accelerated). The bridge connected a DHCP server (feed them address) (DHCP server setup is a corner button....), then this setup connected by a NAT to the WAN, the wan connected a interface (eth1), what is DHCP client ask a access to the "internet". Why show 5 menu this structure?
I hate this GUI, sorry guys. :frowning:
Every part is perfect fit one tab.
tadawson:
"Not need to use it." I agree! What WIFI part is need to work local wifi, and what wifi tab is not necessary and only need the capsman settings? How can I know, that's is important or not? A lot of wifi tab, and only 3 is need the local wifi, and the left 8 is the caps. Of course not side by side or one page the local wifi, and the caps the other pack... If I not use the parameter (keep empty), the system not working... I add one by one, then when every part is filled not working too...
I can set 2 TAB the SSID. :smiley: Why?
If string box (SSID) already filled, then other SSID sections is automatic filled and /or inactive the box... I feel the user error a lot of time, but the GUI is terrible not user friendly....
If the capsman handle something, why not has any bigger capsman (or cap) menu? Right side small corner you found as the first image show? Who think this is the best place the capsman settings? :smiley: SSID already has 2 TAB, but a whole ecosystem is a small button of a tab right side corner? Really?
Please, I feel the user error in my side, but not try to protect the chaotic GUI and undocumented stuff.
If I have a good documentation, not come here the forum. :smiley:
I found it the solutions!
This part is meaningless!
/interface wifi
set wifi1 configuration.manager=capsman-or-local disabled=no
The GUI show two options:
Wifi/Wifi tab/wifi1 double click/Configuration tab: manager (capsman-or-local) and general tab: Enabled (true).
Second options:
Wifi/Configuration tab/ wifi1 double click/manager (capsman-or-local) and top of the tab is Enabled...
What is the good GUI area of this config file?
Where can I found this set in the GUI:
/interface wifi cap
set caps-man-addresses=127.0.0.1 enabled=yes slaves-static=no
Address? There is no enabled. Capsman button? There is no any address or slaves-static options. :slight_smile:
The search bar at the top not show any possibilities to the slaves-static words.
I found! The CAP button hide this part! :slight_smile: The search is not working.
I do every step this config:
and the result is:
no connection to CAPsMAN, managed locally
And not working. :smiley:
# MikroTik RouterOS v7 configuration
# Device:  L009UiGS-2HaxD-IN (L009UiGS-2HaxD-IN)
# Role:    Router + CAPsMAN
# Created: 2026-10-24 19:31 UTC with the eXtreme Hosting MikroTik Configurator
#          https://extremehosting.nl/configurator/en/mikrotik/
# Syntax:  https://manual.mikrotik.com/docs/introduction
# Target:  RouterOS 7.21 up to 7.23
# Licence: this configuration is yours to use without restriction.
#          The tool itself is proprietary: https://extremehosting.nl/configurator/license/
# Apply on a device WITHOUT configuration (/system reset-configuration no-defaults=yes skip-backup=yes),
# with Safe Mode active (Ctrl+X in the terminal). Review every line before pasting.
add comment="genconf" name=bridge protocol-mode=rstp
add name=WAN comment="genconf"
add name=LAN comment="genconf"
add comment="genconf" interface=ether1 list=WAN
add comment="genconf" interface=bridge list=LAN
/interface wifi capsman
set enabled=yes interfaces=bridge require-peer-certificate=no upgrade-policy=suggest-same-version
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disable-pmkid=yes ft=yes ft-over-ds=yes name=sec-office passphrase=123456789 wps=disable
/interface wifi datapath
add bridge=bridge name=dp-lan
/interface wifi channel
add band=2ghz-ax name=ch-2ghz width=20/40mhz
add band=5ghz-ax name=ch-5ghz skip-dfs-channels=10min-cac width=20mhz
/interface wifi configuration
add channel=ch-2ghz country=netherlands datapath=dp-lan mode=ap name=cfg-office-24ghz security=sec-office ssid=Office
/interface wifi provisioning
add action=create-dynamic-enabled comment="2.4ghz" master-configuration=cfg-office-24ghz name-format=cap-%I-24ghz supported-bands=2ghz-ax,2ghz-n,2ghz-g
/interface wifi
/interface wifi cap
add bridge=bridge comment="genconf" interface=ether2
add bridge=bridge comment="genconf" interface=ether3
add bridge=bridge comment="genconf" interface=ether4
add bridge=bridge comment="genconf" interface=ether5
add bridge=bridge comment="genconf" interface=ether6
add bridge=bridge comment="genconf" interface=ether7
add bridge=bridge comment="genconf" interface=ether8
add bridge=bridge comment="genconf" interface=sfp1
/ip dhcp-client
add add-default-route=yes comment="WAN1" default-route-distance=1 interface=ether1 use-peer-dns=yes use-peer-ntp=no
set allow-remote-requests=yes cache-size=4096 servers=9.9.9.9,149.112.112.112
/ip firewall address-list
add address=127.0.0.0/8 comment="genconf: RFC6890" list=bad_ipv4
add address=192.0.0.0/24 comment="genconf: RFC6890" list=bad_ipv4
add address=192.0.2.0/24 comment="genconf: RFC6890 documentation" list=bad_ipv4
add address=198.51.100.0/24 comment="genconf: RFC6890 documentation" list=bad_ipv4
add address=203.0.113.0/24 comment="genconf: RFC6890 documentation" list=bad_ipv4
add address=240.0.0.0/4 comment="genconf: RFC6890 reserved" list=bad_ipv4
add address=0.0.0.0/8 comment="genconf: RFC6890" list=not_global_ipv4
add address=10.0.0.0/8 comment="genconf: RFC6890" list=not_global_ipv4
add address=100.64.0.0/10 comment="genconf: RFC6890" list=not_global_ipv4
add address=169.254.0.0/16 comment="genconf: RFC6890" list=not_global_ipv4
add address=172.16.0.0/12 comment="genconf: RFC6890" list=not_global_ipv4
add address=192.0.0.0/29 comment="genconf: RFC6890" list=not_global_ipv4
add address=192.168.0.0/16 comment="genconf: RFC6890" list=not_global_ipv4
add address=198.18.0.0/15 comment="genconf: RFC6890 benchmark" list=not_global_ipv4
add address=255.255.255.255/32 comment="genconf: RFC6890" list=not_global_ipv4
add address=224.0.0.0/4 comment="genconf: multicast" list=bad_src_ipv4
add address=255.255.255.255/32 comment="genconf: RFC6890" list=bad_src_ipv4
add address=0.0.0.0/8 comment="genconf: RFC6890" list=bad_dst_ipv4
add address=224.0.0.0/4 comment="genconf: RFC6890" list=bad_dst_ipv4
/ip firewall raw
add action=drop chain=prerouting comment="genconf: drop bogon IP's" src-address-list=bad_ipv4
add action=drop chain=prerouting comment="genconf: drop bogon IP's" dst-address-list=bad_ipv4 in-interface-list=WAN
add action=drop chain=prerouting comment="genconf: drop bogon IP's" src-address-list=bad_src_ipv4
add action=drop chain=prerouting comment="genconf: drop bogon IP's" dst-address-list=bad_dst_ipv4 in-interface-list=WAN
add action=drop chain=prerouting comment="genconf: drop non global from WAN" in-interface-list=WAN src-address-list=not_global_ipv4
add action=drop chain=prerouting comment="genconf: drop bad UDP" port=0 protocol=udp
add action=accept chain=input comment="genconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=input comment="genconf: drop invalid" connection-state=invalid
add action=accept chain=input comment="genconf: accept ICMP" protocol=icmp
add action=accept chain=input comment="genconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="drop DNS from WAN (no open resolver)" dst-port=53 in-interface-list=WAN protocol=udp
add action=drop chain=input comment="drop DNS from WAN (no open resolver)" dst-port=53 in-interface-list=WAN protocol=tcp
add action=drop chain=input comment="genconf: drop all not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="genconf: accept in ipsec policy" ipsec-policy=in,ipsec
add action=accept chain=forward comment="genconf: accept out ipsec policy" ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="genconf: fasttrack" connection-state=established,related
add action=accept chain=forward comment="genconf: accept established,related, untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="genconf: drop invalid" connection-state=invalid
add action=drop chain=forward comment="genconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="genconf: masquerade" ipsec-policy=out,none out-interface-list=WAN
/ipv6 firewall address-list
add address=::/128 comment="genconf: unspecified address" list=bad_ipv6
add address=::1/128 comment="genconf: lo" list=bad_ipv6
add address=fec0::/10 comment="genconf: site-local" list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment="genconf: ipv4-mapped" list=bad_ipv6
add address=::/96 comment="genconf: ipv4 compat" list=bad_ipv6
add address=100::/64 comment="genconf: discard only" list=bad_ipv6
add address=2001:db8::/32 comment="genconf: documentation" list=bad_ipv6
add address=2001:10::/28 comment="genconf: ORCHID" list=bad_ipv6
add address=3ffe::/16 comment="genconf: 6bone" list=bad_ipv6
/ipv6 firewall filter
add action=accept chain=input comment="genconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="genconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="genconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="genconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="genconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="genconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="genconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="genconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="genconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="genconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="genconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="genconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="genconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="genconf: accept HIP" protocol=139
add action=accept chain=forward comment="genconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="genconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="genconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="genconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="genconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Amsterdam
/system ntp client
set enabled=yes mode=unicast servers=pool.ntp.org,time.cloudflare.com
/system package update
set channel=stable
/system routerboard settings
set auto-upgrade=yes
/ip service
set winbox disabled=no
set ssh disabled=no
set www disabled=yes
set www-ssl disabled=yes
set api disabled=yes
set api-ssl disabled=yes
set ftp disabled=yes
set telnet disabled=yes
/ip ssh
set strong-crypto=yes
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
/tool bandwidth-server
set enabled=no
/system identity
set name=L009-wifi
/user
set admin password=12345678
But yet, if works simply and well for most of us . . . .
I DO agree, though, that Mikrotik documemtation heartily sucks. Explaining fields with no examples of common use is largely useless. (This has been a sore spot for me professionally . . . products I have beennresponsiblemfor, I have mandated that docs be more task-centric than item centric. IE, a doc should cover "Wireless Configuration" as a process, not just tell you that the SSID field on a form is where you enter the SSID . . . . pretty much self defining and useless) Also, videos based on obsolete ROS and WB really should be taken down by thier creators, since all they tend to do is confuse people.
On the WiFi menus, the only tabs I regard as unique to CapsMan are the "Remote Cap" and "Provisioning" tabs. The rest can be used as desired. Again, just because something is there does not mandate it's use - almost everything has a useable default if no entered. The WiFi setup allows you to subdivide your config to allow larger configs to no incessantly duplicate things. Myself, I have "channel" settings for frequencies, "Security" settings for logins, "Configuration" entries for baseline SSID configs, and tie them together as needed in provisioning and config. Datapath can be ignored if not using VLANs - it defaults to a working config.
You can do this all in one place for a simple config, though. If, for instance, you specify a "Channel" entry, you will see the corresponding entries appear in the config. Your could also not select a Channel entry, and just enter that stuff in the config form. Your choice.
Myself, I have 4 AP's that radiate 13 different signals/SSIDs, on coordinated frequencies. This is via 6 channel entries, and 6 configurations, with the specific SSIDs presented byneach radio/AP defined in provisioning (master and slave configs).
Yes, the old wireless driver was far less complex, but also far more restrictive in large deployments.
So, to deploy a CapsMan config, my process is:
  1. Get the CapsMan server device running alone - CapsMan turned off.
  2. Get DHCP (or static) assignments setup for the AP's.
  3. Initialize the AP's in CAP mode, confirm that they get an IP (or configure the IP if static) and can be reached.
  4. On the CapsMan controller, enable CapsMan, and set the interface to the one that connects tomthe AP's (typically the bridge).
    At this point, the remote AP's should populate in the "Remote CAP" tab
  5. Create configurations however you desire, and assign to the remote CAPs in provisioning, either globally, or via MAC specific entries. You WILL need separate 2.4G and 5G entries.
  6. If needed, on the "Radios" tab, select one and then hit "Provision" and this will send your config to it. It should appear in the WiFi tab.
That's it! Don't get creative and add other steps - they are more likely to break things! Once this is working, tweak as desired, keeping backups in case you break something.
(FWIW, this is based on ROS 7.21 and above, and WinBox 4.2 and above, although I am not a heavy WinBox user . . . mostly WebFig from an Android tablet, but the function is the same.)
And I concur - the obsession with CLI in a lot of docs is irritating . . . . although there are a few things that require it (device-mode springs to mind . . . ).
Looking at your config, it looks like you have been changing things best left alone. My working CapsMan config is:
set ca-certificate=auto certificate=auto enabled=yes interfaces=bridge upgrade-policy=none
Screw with the cert stuff, and it breaks!
This config is generated by the suggested website:
But yet it does not work, making it complete and total crap . . .
Why you persist in using it is beyond my comprehension.
I offer you a known good config based on current versions and a working environment, and you persist in doing other things.
I'm out.
Thank you your any answers!
I reply to your stuff but you can leave as you wish.
"Select "CapsMan", tick enabled OK, select the interface the AP's are on (bridge OK), and the radios and such should discover and appear in CapsMan (internal wifi device visible in radios tab (name:wifi1) OK). Zero need for VLANs or anything else extra unless you want them (NO Vlan, OK). Configure from there."
Configure what?
"qcom based CapsMan package" OK WinBox 4.4 use as you suggest. OK
"CAPSMAN menu simply sets up CapsMan to be able to talk to CAP devices." OK
"I think that you may be errantly trying to use info on the older "Wireless" based CapsMan on the second generation CapsMan, which is not the same." OK I use the new stuff
Open topic, what kind of config need to work my internal WIFI with capsman controller?
"You configure the radios via the other tabs and provisioning rules. "
"You should have tabs for Configuration, Security, Channel, Datapath etc. within WiFi to do the specific config."
"If you have the AP's in CAP mode" My internal wifi module is a cap mode ap this moment? If yes, my cap is need to turn on too?
eth8 external cAP AX is a easy answer to CAP device...
The other answers from you is focus the external cAP AX and other external stuff. I not focus this yet.
If working my wifi with capsman controller I step forward my external AP.
I turn on the CAP too and give interface the bridge, so my internal WIFI is write this: managed by CAPsMAN 192.168.88.1
But the phone not see any wifi signal from this router (wifi).
Base setup is visible only one radio, the internal wifi in the L009i.
0  L radio-mac=... tx-chains=0,1 rx-chains=0,1 bands=2ghz-g:20mhz,2ghz-n:20mhz,20/40mhz,2ghz-ax:20mhz,20/40mhz
     ciphers=tkip,ccmp,gcmp,ccmp-256,gcmp-256,cmac,gmac,cmac-256,gmac-256 min-antenna-gain=4 countries=all
     2g-channels=2412,2417,2422,2427,2432,2437,2442,2447,2452,2457,2462,2467,2472 max-vlans=128 max-interfaces=8 max-station-interfaces=3
     max-peers=128 hw-type="QCA5018" hw-caps=sniffer,qos-classifier-dscp,spectral,channel-switch,6,hw-protection-mode interface=wifi1
If I turn on the CAP, I see the base radio parameters AND visible the second, not LOCAL with same radio mac address. Why?
1    cap="L009UiGS_@192.168.88.1" radio-mac=... tx-chains=0,1 rx-chains=0,1
     bands=2ghz-g:20mhz,2ghz-n:20mhz,20/40mhz,2ghz-ax:20mhz,20/40mhz ciphers=tkip,ccmp,gcmp,ccmp-256,gcmp-256,cmac,gmac,cmac-256,gmac-256
     min-antenna-gain=4 countries=all 2g-channels=2412,2417,2422,2427,2432,2437,2442,2447,2452,2457,2462,2467,2472 max-vlans=128 max-interfaces=8
     max-station-interfaces=3 max-peers=128 hw-type="QCA5018" hw-caps=sniffer,qos-classifier-dscp,spectral,channel-switch,6,hw-protection-mode
The CAP make a virtual radio?
the result based on this link:
"When CAP connects, CAPsMAN at first tries to bind each CAP radio to CAPsMAN master interface based on radio-mac."
The CAPsMAN inetface never use the master word. The controller and the controlled devices (CAP) is a topology of master slave?
The CAPsMAN only has master interface, for my setup is the bridge?
The CAPsMAN how can add slave interface? :slight_smile:
"If an appropriate interface is found, the radio gets set up using master interface configuration and configuration of slave interfaces that refer to a particular master interface."
How can I see the slave result? What is the indicator of this "found success"?
Why not has a time based flow chart of the "master slave behavior"?
The WiFi setup.
First, you have to have all devices visible in CapsMan, or there is nothing to config . . . and this is where I have been focusing.
And CAP mode should NOT be set on the CapsMan controller - just the remotes.
Once you see everything, only then can you configure SSID's, and you aren't there yet.
When you are, setup login info in the security tab.
Setup the SSID in the configuration tan.
If desired, frequencies in the channels tab.
And then assign those to the radios in the provitioning tab.
And push the provisioning in the radios tab.
CapsMan is NOT for local radios! If all you want to do is configure those, leave CAP and CAPSMAN off on that device, and do so via the same menus. CapsMan simply adds the remote devices to that you can control them all from the same place. You do so with the same menus under the WiFi section.
Thank you boss, you earn my award of patience and supportive help!
But I'm tired.
"And CAP mode should NOT be set on the CapsMan controller - just the remotes."
How to use the internal wifi to under the capsman controller? To turn on the cap... In the controller device. One device controlling and controlled same time. The internal wifi and the eth8 toooo.
BTW thank you, really!
The topic is closed. :slight_smile:
I order the competition company hardware pack. Sorry Mikrotik, please write a good documentation next time.
The most problematic is not my unsuccessful user error side or money lost, but I work/made a small cyber security advisor company and focus mostly the AI and sensitive data protections (encrypt, cloud, sensitive data share, hardware leaking personal data), and the half part of the company is the networking, of course not my knowledge based (as everybody see) (I have a bunch of smart-as guy around me with networking), but I not suggest anybody to buy this company stuff if the documentation is full of missing sections. And why I'm not asking my colleagues to help? I wanna see the official Mikrotik forum/support how its working. Everybody try to help, but nobody can point a normal documentation of what is the base step by step trough the whole setup from the official Mikrotik site, because is doesn't exist. Explain the capsman structure, what is master and what is slave, when the GUI never use slave words when parameterize anything. The wifi sections not clear what is use the internal wifi and what is use the capsman handling wifi part. What is local and what is global tab? I don't care anymore, just saying. :smiley: When the capsman ON why is available the local wifi part? And vice-versa...
(My company not sell hardware, just suggest to choose wise hardware... Mikrotik is step back the no2)
Why is so annoying the Mikrotik front end and documentation part? (the fancy video not help of the missing documentation) The hardware is so beautiful, massive, long working time, I love every details, but not the GUI of Winbox... The script is what turn on automatic the LTE backup WAN interface is using a wifi class what is only visible in the forum in the past... Not the documentation of official website. :smiley:
My no1 company WAS the Mikrotik. :frowning:
Bye all! And thank you!
Best regards,
Jack
Quite simply: You don't. They appear in the menus locally without CapsMan, the same way the remote ones do with it.
