I have a setup of one MikroTik Router and multiple cAP AX Accespoint.
My setup consists of one WiFi Configuration and one WiFi Provisioning. This works well and the SSID’s appear on all Accespoints.
But I’m unsure how to perform “fine-tuning” now.
E.g. how to set 2Ghz to 20Mhz and 5Ghz to 80Mhz, how to select per Accespoint Channels and things like that.
Also recommended settings for these parameters would be nice.
It is better if you separate the 2 and 5 GHz configurations; this is the best approach for MikroTik.
For fine-tuning, I recommend:
Enable Multicast Enhance
Enable Station Roaming
Enable RRM and WNM
Create a neighbor group for roaming (ft and Station Roaming has to be active for it to work)
Enable FT and FT over DS
You can define multiple channels in the Channel Config tab; the APs will then choose the best channel for themselves. Additionally, it is recommended to add a reselect time (range) so the APs can automatically switch channels to avoid Wi-Fi issues. However, this depends on the environment. You cant set it for each AP seperately.
Do not use DFS channels; in MikroTik you can skip them by setting Skip DFS Channels to all
Thanks for your very comprehensive list of recommended settings!
I think my understanding problem lies in the 2 and 5 GHz configuration separation. I think you mean using two configurations with the same SSID.
But how can I apply the 2GHz config to just 2GHz radios and vice-versa?
Hmm, to my understanding this should work and deploy three SSID’s to each radio. But it just takes one SSID (the one without -Xg).
Or is this understanding wrong?
I use Webfig, because I go cross eyed with the command line equivalents. So WiFi -> Provisioning -> New, you get to choose a master configuration and slave configurations too. You can add more than 1 slave if you want.
As you appear to have different wireless interface slaves for 5GHz and 2GHz, but the same master, you will need to provision separately for the 2 frequency bands, duplicating the master configuration and selecting the slave appropriate to the band.
I have left it running with these settings for a bit now. But it seems not that stable, looks like especially when falling back from 5G to 2G.
Any idea what could be tuned?
I think you want steering on both configurations selected.
station-roaming is for radios set to station (and not ap).
When you want to have auto channel...I would really advice to use reselect-interval to have a background scan periodically checking if you use the best frequency:
When switching to a DFS channel, it will take 1 minute (or 10 minutes in case of a frequency in between 5570MHz and 5650MHz) to perform (additional) radar detection.
In my case I get switched to 2.4GHz in case of switch to DFS channel, and automatically reconnect to 5GHz when that radio is available.
Though I prefer fixed channels, my neighbors don't.
Apply that piece of config I listed above and then do that rescan and watch if it actually drops clients. Since DFS is avoided… it shouldn’t shut down clients from what you are telling me.
Because hitting scan in cap-man disconnects everything from the radio.
AFAIK you can't do a background scan manually. If you want to test, you would have to set the reselect-interval very low. Don't know if the background scan is logged, not when having default logging settings.
Indeed, by triggering a scan (I assume that is what you mean by rescan), all clients are dropped.
Unattended radio scan (e.g. if property reselect-interval is configured) is background scan, so normal operation of AP (on old frequency) resumes.
However if reselection algorithm chooses to start using a DFS frequency, then there will be a pause in AP operation ... but not because of "listening" for radar, it's because of regulation requiring a "listen only" period before active use of selected frequency. This part can't really be done "in the background" because own Tx and Rx will interfere with "listening" on the new frequency (own Tx would also interfere if there was an additional dedicated receiver just for channel scanning).
Manually executing radio scan is a disruptive operation (snooping is as well) but that really shouldn't be a part of normal operations..
I'm not a native English speaker ... so the quoted distinction (while I was writing about continuation of normal operations but used word resume) is due to my mediocre lingustic skills.
