Hi!
I have something like this:
RouterOS 7.4
VLAN 110 - Home network
VLAN 190 - Guest network
VALN 3 - Management network
On HAPac:
Acts like switch with CAPsMAN and CAP onboard. Trunked with “main” L3-switch.
All ethernet ports bridged.
Wlan interfaces automaticaly bridged by CAPsMAN provisioning.
/interface/ethernet/switch/port> print
Columns: NAME, SWITCH, VLAN-MODE, VLAN-HEADER, DEFAULT-VLAN-ID
# NAME SWITCH VLAN-MODE VLAN-HEADER DEFAULT-VLAN-ID
0 ether1 switch1 secure add-if-missing 3
1 ether2 switch1 secure always-strip 110
2 ether3 switch1 secure always-strip 110
3 ether4 switch1 secure always-strip 110
4 ether5 switch1 secure always-strip 3
5 switch1-cpu switch1 secure leave-as-is 3
/interface/ethernet/switch/vlan> print
Columns: SWITCH, VLAN-ID, PORTS
# SWITCH VLAN-ID PORTS
0 switch1 110 ether1
ether2
ether3
ether4
1 switch1 190 ether1
2 switch1 3 ether1
ether5
switch1-cpu
/interface/bridge/port> print
Flags: I - INACTIVE; D - DYNAMIC; H - HW-OFFLOAD
Columns: INTERFACE, BRIDGE, HW, PVID, PRIORITY, PATH-COST, INTERNAL-PATH-COST, HORIZON
# INTERFACE BRIDGE HW PVID PRIORITY PATH-COST INTERNAL-PATH-COST HORIZON
0 H ether1 bridge1 yes 1 0x80 10 10 none
1 I H ether2 bridge1 yes 1 0x80 10 10 none
2 I H ether3 bridge1 yes 1 0x80 10 10 none
3 I H ether4 bridge1 yes 1 0x80 10 10 none
4 I H ether5 bridge1 yes 1 0x80 10 10 none
5 D wlan1 bridge1 110 0x80 10 10 none
6 D wlan3 bridge1 190 0x80 10 10 none
7 D wlan2 bridge1 110 0x80 10 10 none
8 D wlan4 bridge1 190 0x80 10 10 none
/interface/vlan> print
Flags: R - RUNNING
Columns: NAME, MTU, ARP, VLAN-ID, INTERFACE
# NAME MTU ARP VLAN-ID INTERFACE
0 R vlan110 1500 enabled 110 bridge1
1 R vlan190 1500 enabled 190 bridge1
Everything works fine, except that the clients of CAP3 do not receive IP-settings from the DHCP server.
What I am doing wrong?..
Please help!
Without having a crystal ball and you not providing details on config, nobody can know.
/export hide-sensitive file=
Post between [code __] quotes after reviewing the output for private info.
Ok.
Here it is:
# jul/25/2022 16:17:59 by RouterOS 7.4rc2
# software id = CJB9-4KHN
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = 6F12066E9CD7
add name=bridge1
set [ find default-name=ether5 ] poe-out=off
/interface wireless
# managed by CAPsMAN
# channel: 2412/20-Ce/gn(17dBm), SSID: KNTP, local forwarding
set [ find default-name=wlan1 ] disabled=no ssid=MikroTik
# channel: 5980/20-Ceee/ac(28dBm), SSID: KNTP, local forwarding
set [ find default-name=wlan2 ] disabled=no ssid=MikroTik
/interface vlan
add interface=bridge1 name=vlan110 vlan-id=110
add interface=bridge1 name=vlan190 vlan-id=190
/caps-man configuration
add country=russia4 datapath.bridge=bridge1 .local-forwarding=yes .vlan-id=\
110 .vlan-mode=use-tag name=KNTP security.authentication-types=\
wpa-psk,wpa2-psk ssid=KNTP
190 .vlan-mode=use-tag name=KNTP_Guest security.authentication-types=\
wpa-psk,wpa2-psk ssid=KNTP_Guest
/caps-man interface
add configuration=KNTP disabled=no l2mtu=1600 mac-address=6C:3B:6B:73:E1:24 \
master-interface=none name=HAPac_Admin-1 radio-mac=6C:3B:6B:73:E1:24 \
radio-name=6C3B6B73E124
add configuration=KNTP_Guest disabled=no l2mtu=1600 mac-address=\
6E:3B:6B:73:E1:24 master-interface=HAPac_Admin-1 name=HAPac_Admin-1-1 \
radio-mac=00:00:00:00:00:00 radio-name=6E3B6B73E124
add configuration=KNTP disabled=no l2mtu=1600 mac-address=6C:3B:6B:73:E1:23 \
master-interface=none name=HAPac_Admin-2 radio-mac=6C:3B:6B:73:E1:23 \
radio-name=6C3B6B73E123
6E:3B:6B:73:E1:23 master-interface=HAPac_Admin-2 name=HAPac_Admin-2-1 \
radio-mac=00:00:00:00:00:00 radio-name=6E3B6B73E123
add configuration=KNTP disabled=no l2mtu=1600 mac-address=B8:69:F4:F8:FF:8A \
master-interface=none name=WAPac_Boss-1 radio-mac=B8:69:F4:F8:FF:8A \
radio-name=B869F4F8FF8A
BA:69:F4:F8:FF:8A master-interface=WAPac_Boss-1 name=WAPac_Boss-1-1 \
radio-mac=00:00:00:00:00:00 radio-name=BA69F4F8FF8A
add configuration=KNTP disabled=no l2mtu=1600 mac-address=B8:69:F4:F8:FF:89 \
master-interface=none name=WAPac_Boss-2 radio-mac=B8:69:F4:F8:FF:89 \
radio-name=B869F4F8FF89
BA:69:F4:F8:FF:89 master-interface=WAPac_Boss-2 name=WAPac_Boss-2-1 \
radio-mac=00:00:00:00:00:00 radio-name=BA69F4F8FF89
add configuration=KNTP disabled=no l2mtu=1600 mac-address=64:D1:54:07:D2:B4 \
master-interface=none name=WAPac_Eatery-1 radio-mac=64:D1:54:07:D2:B4 \
radio-name=64D15407D2B4
66:D1:54:07:D2:B4 master-interface=WAPac_Eatery-1 name=WAPac_Eatery-1-1 \
radio-mac=00:00:00:00:00:00 radio-name=66D15407D2B4
add configuration=KNTP disabled=no l2mtu=1600 mac-address=64:D1:54:07:D2:B3 \
master-interface=none name=WAPac_Eatery-2 radio-mac=64:D1:54:07:D2:B3 \
radio-name=64D15407D2B3
66:D1:54:07:D2:B3 master-interface=WAPac_Eatery-2 name=WAPac_Eatery-2-1 \
radio-mac=00:00:00:00:00:00 radio-name=66D15407D2B3
set 0 default-vlan-id=3 vlan-header=add-if-missing vlan-mode=secure
set 1 default-vlan-id=110 vlan-header=always-strip vlan-mode=secure
set 2 default-vlan-id=110 vlan-header=always-strip vlan-mode=secure
set 3 default-vlan-id=110 vlan-header=always-strip vlan-mode=secure
set 4 default-vlan-id=3 vlan-header=always-strip vlan-mode=secure
set 5 default-vlan-id=3 vlan-mode=secure
/caps-man manager
set enabled=yes upgrade-policy=suggest-same-version
/caps-man manager interface
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=KNTP name-format=\
identity slave-configurations=KNTP_Guest
add independent-learning=yes ports=ether1,ether2,ether3,ether4 switch=switch1 \
vlan-id=110
add independent-learning=yes ports=ether1 switch=switch1 vlan-id=190
add independent-learning=yes ports=ether1,ether5,switch1-cpu switch=switch1 \
vlan-id=3
/interface wireless cap
set bridge=bridge1 caps-man-addresses=127.0.0.1 enabled=yes interfaces=\
wlan1,wlan2
add address=10.1.1.4/24 interface=bridge1 network=10.1.1.0
set servers=10.1.10.11
add disabled=no dst-address=0.0.0.0/0 gateway=10.1.1.3 routing-table=main \
suppress-hw-offload=no
/system clock
set time-zone-name=Europe/Moscow
/system identity
set name=HAPac_Admin
For some obscure reason I never got notifications from your post (and plenty of others ! Must be something with the forum sw)
Where is your DHCP server ? Other device ?
As for the VLAN-setup on that device, it is advised to use bridge for VLAN handling, not switch chip.
Can you reach other devices on those VLANs from that hap AC ? If not, the problem is there.
I have no experience using switch chip, so can not assist further.
See this post for more info / conceptual setup:
About the use of VLAN in general. The implementation of VLAN on switch chips makes sense only on “real” switches. CRS type. Where hardware offloading really gives noticeable results. For home conditions, as well as for small offices - it makes no sense. Wi-Fi modules are not connected to switch chips, so their traffic will still be processed through the central processor. And you won’t win anything. I’ve done some experimentation with VLAN on bridges and switch chips. Therefore, I recommend that you abandon this scheme.
If you really want to - try switching from local forwarding CAPsMAN forwarding mode.
woland
August 2, 2022, 11:56am
7
Beware: HW bridging saves CPU+Power. You might be right on an edge AP, but I have seen improvement on different HEX and HAPac devices, where I avoid using software bridging for switching between the 5 ports. It also makes sense if you are chaining APs (CAPac, WAPac). Traffic from the chained AP does not use CPU on the first AP. Using of course different VLANs for management and WLAN traffic separation.
Also: don´t confuse L2 switching and L3 HW Offloading (which you don´t get with the previously mentioned devices)…
BR
W
Thank you all for your response!
DHCP-server lives on dedicated server in VLAN 110. And again: wireless clients (home and guest) connected to CAP1 and CAP2 receive ip-addresses without problems.
The wireless client connected to CAP3 does not have access to the wired network even if I manually specify the IP settings on the wireless client.
The probleme is somewhere between bridge1 and switch-chip. I guess..
Before configuring, I have read:
https://wiki.mikrotik.com/wiki/Manual:Basic_VLAN_switching
https://wiki.mikrotik.com/wiki/Manual:Switch_Chip_Features
https://wiki.mikrotik.com/wiki/Manual:Interface/Bridge
https://wiki.mikrotik.com/wiki/Manual:CAPsMAN_with_VLANs
..and I was sure that I did everything right.
I think I understand how the switch-chip works with “software” bridge. In particular, the work of the HAPac QCA8337 switch-chip.
However, wireless clients on CAP3 do not have access to the wired network.
I know that I may use only one ether-port and bridge, similar to other devices (WAPac`s).
But, my goal is to use the switched ports with VLAN switching on a hardware level, because the capabilities of HAPac allow it to be done. And besides I just need this “free” switched ports.
BR
W
I’m sorry, but do you have any ideas about solving my problem?
woland
August 5, 2022, 9:21am
10
I´m not entirely sure what your problem is. I am not that often configuring my MT devices, but without a guarantee I guess, it might be the following:
vlan-header=always-strip should be changed to vlan-header=leave-as-is
https://help.mikrotik.com/docs/display/ROS/Basic+VLAN+switching#BasicVLANswitching-Otherdeviceswithabuilt-inswitchchip
On QCA8337 and Atheros8327 switch chips, a default vlan-header=leave-as-is property should be used. The switch chip will determine which ports are access ports by using the default-vlan-id property. The default-vlan-id should only be used on access/hybrid ports to specify which VLAN the untagged ingress traffic is assigned to.
Yes, I saw this point in the manual. And initially did exactly as you describe - configured “live-as-is”. Unsuccessfully.
Therefore, I tried to tell the system explicitly what to do with the headers - “add-if-missing” and “always-strip”. Unsuccessfully too..
Ok. Thank you anyway!
Ok. I found solution. Perhaps it will be useful to someone.
So, this part of config:
add independent-learning=yes ports=ether1,ether2,ether3,ether4 switch=switch1 vlan-id=110
add independent-learning=yes ports=ether1,ether5,switch1-cpu switch=switch1 vlan-id=3
..should look like this:
add independent-learning=yes ports=ether1,ether2,ether3,ether4,switch1-cpu switch=switch1 vlan-id=110
add independent-learning=yes ports=ether1,switch1-cpu switch=switch1 vlan-id=190
In other words, switch1-cpu interface must be present in every “switch vlan” configuration.
