I get to know the CAPsMAN topic. I tried a following:
CAPsMAN: RB951G-2HnD
Cap1: Wifi of RB951G-2HnD
Cap2: Wifi of RBmAP-2n
My first step was success: one SSID on both devices. Everithing works fine.
But when I set a second SSID (guest wifi)… No one wifi device can connect to the second SSID (laptop, PC, mobile phone). The second SSID is visible, but isn’t usable.
FYI:
I created 2 config for the 2 SSID (Name, Mode, SSID, Country, Bridge, Security). I tested them seperately, they work fine.
I created 2 Provisoning for the 2 devices (RB951G-2HnD and RBmAP-2n).
I add a new CAP interface in the CAPsMAN (RB951G-2HnD and/or RBmAP-2n), select a config (SSID1 or SSID2), set the phisical interface Channel/Frequency, Width, Band, Extension Channel) … and works fine (Master, Bounded)
But when add a second wifi/SSID (Virtual AP - the Master Interface is the first one - of course) the second wifi/SSID appears in the WinBox (Slave, Bounded). It is visible for any wireless capable device - laptop, PC, mobile - but isn’t usable. They can’t connect to second wifi/SSID ( The first wifi/SSID contiues to function.
Is it my fault?
I’ve tried these with CAPsMAN-v1.
I’m having a similar issue with Capsman V2 running on 6.23.
I’ve got a primary SSID running on an interface and datapath is to bridge1 on the capsman unit.
If I then attach a sub-interface with a new SSID (and corresponding datapath to bridge2) then I can see the wireless network, but I just cannot connect to it at all.
If I switch the config to the primary interface then I can connect fine.
There is nothing logged on the capsman unit (with cap logging on) when i try to connect to the sub-interface ssid.
I’m trying with 6.24, but still can’t get the second SSID to connect. I’m still not sure there isn’t something wrong with my config and I’d like to check before contacting support
JasonEde, specify different MAC address for that VirtualAP as you can’t have the same MAC address. Usually when you add a new VirtualAP it automatically changes the MAC address.
Thank you for advice.
Today faced with this problem. After reset configuration AP and further configuration second SSID (Virtual AP) users can see second SSID but could not connect to it.
I changed MAC address of the Virtual AP. After changing MAC address users can connect.
