I am experimenting again with CAPSMAN 2. I am using my CCR2004 as my CAPSMAN, and my two hAP AX2 APs as CAPs. Everything is running 7.16beta6 My question is, what is the correct way to manually specify both 2.4Ghz and 5Ghz channels for each AP? I like to set the channels by hand to make sure I don’t have overlap.
This question was answered for my by support!
They said the following:
"You can define action for provision rules to create-enabled and then after they are provisioned change frequency, or You can specify range or just two frequencies “5180,5500” and provision second device after first has done it, then the second cAP should choose other frequency. "
