Hello everyone,
I'm opening this new thread for an issue that I haven't been able to solve, even after trying all the documented solutions found here on the forums and elsewhere. Any insights would be greatly appreciated.
Setup Details:
- Model: hAP ax^3 (C53UiG+5HPaxD2HPaxD)
- RouterOS Version: 7.19.6 (upgraded from 7.19.4 while trying to solve this issue).
Problem Summary: I have a Hotspot with a captive portal that works perfectly on iOS devices (iPhone). When connecting to the guest network, the portal pops up automatically without any issues.
However, on Android devices (tested on multiple models and versions), the captive portal does not launch automatically. The device remains connected with a "Connected, no internet" status. To get access, the user must manually open a browser and navigate to the gateway IP (192.168.20.1) or the DNS name (login.imprepide.com).
Troubleshooting Steps Taken (Without Success):
- DHCP & DNS Configuration: The explicit DNS server configuration was removed from the Hotspot's network settings to allow the service to properly handle redirects.
- HTTPS Redirect Investigation: It was confirmed that HTTPS redirection is a common cause of issues on Android.
- The
HTTPS Redirectoption was missing from the GUI (WinBox/WebFig) on both 7.19.4 and 7.19.6. - Discovered that this is intentional behavior in RouterOS 7 and is now controlled by assigning (or not assigning) an SSL certificate.
- The Hotspot profile is now configured with
ssl-certificate=noneto prevent HTTPS redirection, as per current best practices.
- The
- Android-Specific Fix: A static DNS entry was added to the router to force portal detection on Android. The entry exists and is configured correctly:
name=connectivitycheck.gstatic.comaddress=192.168.20.1
- Client-Side Diagnostics (Android): All recommended tests were performed on the Android client device.
- Confirmed the device is connected to the correct Wi-Fi network.
- Confirmed the device receives a valid IP address from the Hotspot's DHCP pool (
192.168.20.xxx). - The "Private DNS" feature was disabled on the phone.
- A clean test was performed: "Forgetting" the network on the phone and rebooting the device completely before reconnecting.
Despite all of these steps, the behavior persists: iOS works, Android fails.
[admin@MKT-ImprePIDE-PZO] > / export
2025-09-23 21:24:31 by RouterOS 7.19.6
software id = 5SBJ-LU26
model = C53UiG+5HPaxD2HPaxD
serial number = xxxxxxxxx
add name=bridge1 vlan-filtering=yes
set [ find default-name=ether5 ] name=GESTION
set [ find default-name=ether1 ] name=ISP
set [ find default-name=ether3 ] name=LIBRE
set [ find default-name=ether4 ] name=NVR
set [ find default-name=ether2 ] name=SWITCH
/interface wireguard
add comment="WG - Admin remoto" disabled=yes listen-port=51820 mtu=1420 name=wg0
/interface vlan
add interface=bridge1 name=vlan10 vlan-id=10
add interface=bridge1 name=vlan20 vlan-id=20
add interface=bridge1 name=vlan30 vlan-id=30
add interface=bridge1 name=vlan99 vlan-id=99
add comment="Puertos trunk 802.1Q" name=TRUNK
add comment="salida a internet" name=WAN
/interface wifi security
add authentication-types="" disabled=no name=sec-open
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=sec-privado
/interface wifi configuration
add mode=ap name=cfg-privado security=sec-privado ssid="ImprePIDE - PZO"
add mode=ap name=cfg-invitados security=sec-open ssid="ImprePIDE - Invitados"
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax configuration=cfg-privado disabled=no
add configuration=cfg-invitados disabled=no mac-address=F6:1E:57:0B:FD:E0 master-interface=wifi1 name=wifi1-invitados
set [ find default-name=wifi2 ] channel.band=2ghz-ax configuration=cfg-invitados disabled=no
add configuration=cfg-privado disabled=no mac-address=F6:1E:57:0B:FD:E1 master-interface=wifi2 name=wifi2-privado
/ip hotspot profile
add dns-name=login.imprepide.com hotspot-address=192.168.20.1 login-by=http-pap name=hs-guest
/ip hotspot user profile
add add-mac-cookie=no idle-timeout=1h keepalive-timeout=1m !mac-cookie-timeout name=guest-1h rate-limit=15M/10M shared-users=50
add name=pool_vlan99 ranges=192.168.99.100-192.168.99.199
add name=pool_vlan20 ranges=192.168.20.50-192.168.20.200
add name=pool_vlan30 ranges=192.168.30.100-192.168.30.199
add name=pool_vlan10 ranges=10.0.0.100-10.0.0.199
add address-pool=pool_vlan99 interface=vlan99 name=dhcp_vlan99
add address-pool=pool_vlan10 interface=vlan10 lease-time=1d name=dhcp_vlan10
add address-pool=pool_vlan20 interface=vlan20 name=dhcp_vlan20
add address-pool=pool_vlan30 interface=vlan30 lease-time=1d name=dhcp_vlan30
/ip hotspot
add address-pool=pool_vlan20 addresses-per-mac=1 disabled=no interface=vlan20 keepalive-timeout=10m name=hs-guest profile=hs-guest
/user group
add name=restonly policy=read,write,rest-api,!local,!telnet,!ssh,!ftp,!reboot,!policy,!test,!winbox,!password,!web,!sniff,!sensitive,!api,!romon
add name=hotspot-api policy=read,write,api,!local,!telnet,!ssh,!ftp,!reboot,!policy,!test,!winbox,!password,!web,!sniff,!sensitive,!romon,!rest-api
/certificate settings
set builtin-trust-anchors=not-trusted
add bridge=bridge1 interface=SWITCH pvid=10
add bridge=bridge1 interface=LIBRE pvid=10
add bridge=bridge1 interface=NVR pvid=30
add bridge=bridge1 interface=GESTION pvid=99
add bridge=bridge1 interface=wifi1 pvid=10
add bridge=bridge1 interface=wifi1-invitados pvid=20
add bridge=bridge1 interface=wifi2-privado pvid=10
add bridge=bridge1 interface=wifi2 pvid=20
/interface bridge vlan
add bridge=bridge1 tagged=bridge1 untagged=SWITCH,LIBRE,wifi1,wifi2-privado vlan-ids=10
add bridge=bridge1 tagged=bridge1 untagged=wifi2,wifi1-invitados vlan-ids=20
add bridge=bridge1 tagged=bridge1 untagged=NVR vlan-ids=30
add bridge=bridge1 tagged=bridge1 untagged=GESTION vlan-ids=99
add interface=ISP list=WAN
/interface wireguard peers
add allowed-address=10.0.250.2/32 comment=iPhone disabled=yes interface=wg0 name=peer1 persistent-keepalive=25s public-key=""
add address=192.168.20.1/24 interface=vlan20 network=192.168.20.0
add address=192.168.30.1/24 interface=vlan30 network=192.168.30.0
add address=192.168.99.1/24 interface=vlan99 network=192.168.99.0
add address=10.0.0.1/24 comment="Privada (VLAN10)" interface=vlan10 network=10.0.0.0
add address=10.0.250.1/24 comment="WG subnet" interface=wg0 network=10.0.250.0
/ip cloud
set ddns-enabled=yes update-time=no
/ip dhcp-client
add interface=ISP use-peer-dns=no
add address=10.0.0.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=10.0.0.1
add address=192.168.20.0/24 gateway=192.168.20.1
add address=192.168.30.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=192.168.30.1
add address=192.168.99.0/24 dns-server=8.8.8.8 gateway=192.168.99.1
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
/ip dns static
add address=192.168.20.1 name=connectivitycheck.gstatic.com type=A
/ip firewall address-list
add address=10.0.0.0/24 comment=Privada list=WG-ALLOWED
add address=192.168.30.0/24 comment=NVR list=WG-ALLOWED
add address=192.168.99.0/24 comment=Gestin list=WG-ALLOWED
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add action=accept chain=input comment="INPUT established/related" connection-state=established,related
add action=drop chain=input comment="INPUT drop invalid" connection-state=invalid
add action=accept chain=input comment="Mgmt via WG" in-interface=wg0
add action=accept chain=input comment="WireGuard desde Internet" dst-port=51820 in-interface=ISP protocol=udp
add action=accept chain=input comment="API para Apps Script" dst-port=443 in-interface=ISP protocol=tcp
add action=drop chain=input comment="Bloquear acceso remoto desde WAN" in-interface=ISP
add action=accept chain=forward comment="FWD established/related" connection-state=established,related
add action=drop chain=forward comment="FWD drop invalid" connection-state=invalid
add action=accept chain=forward comment="WG -> LAN permit" dst-address-list=WG-ALLOWED src-address=10.0.250.0/24
add action=drop chain=forward comment="Isolate VLAN10 -> VLAN20" in-interface=vlan10 out-interface=vlan20
add action=drop chain=forward comment="Isolate VLAN20 -> VLAN10" in-interface=vlan20 out-interface=vlan10
add action=drop chain=forward comment="Isolate VLAN10 -> VLAN30" in-interface=vlan10 out-interface=vlan30
add action=drop chain=forward comment="Isolate VLAN30 -> VLAN10" in-interface=vlan30 out-interface=vlan10
add action=drop chain=forward comment="Isolate VLAN20 -> VLAN30" in-interface=vlan20 out-interface=vlan30
add action=drop chain=forward comment="Isolate VLAN30 -> VLAN20" in-interface=vlan30 out-interface=vlan20
add action=drop chain=forward comment="Guests -> Mgmt drop" in-interface=vlan20 out-interface=vlan99
add action=masquerade chain=srcnat comment="NAT nico" out-interface-list=WAN
/ip hotspot user
add name=guest profile=guest-1h server=hs-guest
/ip hotspot walled-garden
add dst-host=forms.gle
add dst-host=script.google.com
add dst-host=docs.google.com
add dst-host=ssl.gstatic.com
add dst-host=.googleusercontent.com
add dst-host=.googleapis.com
add dst-host=.gstatic.com
add dst-host=imprepide.com
add dst-host=www.imprepide.com
add dst-host=.imprepide.com
/ip service
set ssh disabled=yes
set telnet disabled=yes
set www address=192.168.99.0/24,10.0.0.0/24
set www-ssl address=192.168.99.0/24,10.0.0.0/24 disabled=no
set api-ssl address=192.168.99.0/24,10.0.250.0/24 disabled=yes port=443
set winbox address=192.168.99.0/24,10.0.0.0/24
set api disabled=yes
/system clock
set time-zone-autodetect=no time-zone-name=America/Caracas
/system identity
set name=MKT-ImprePIDE-PZO
/system logging
add topics=hotspot
/system ntp client
set enabled=yes
/system ntp client servers
add address=time.cloudflare.com
add address=time.google.com
add address=pool.ntp.org
/tool netwatch
add comment="Health check nico" down-script=":log warning "Internet caido (sin respuesta de 8.8.8.8)";" host=8.8.8.8 interval=30s timeout=3s type=simple up-script=
":log info "Internet OK (8.8.8.8 responde)";"
The Question: Given that the configuration appears to be 100% correct, follows recommended best practices, and works for one platform (iOS), what could be causing it to fail specifically on Android? Is there a known bug with the combination of RouterOS 7.19.6 and the hAP ax^3 hardware that could affect this? Are there any non-standard Firewall/NAT or Mangle rules that might be required to resolve this?
Any ideas or suggestions would be very welcome. Thanks in advance.
