I have a few issues with my CCR1009-8G-1S-1S.
One issue is the sd card slot, sometimes the usermanager store on that medium disappear, in winbox i can see that usermanager store is on state backup and not active. sometimes it set itself to active, sometimes a reboot helps, i tried two different sd card brands.
Another issue is the flash in the CCR itself, 3 days ago i got a filesystem corruption on the CCR in runtime. I tried to log into my CCR and it told me my username/password is wrong. I did a reboot over the display menu, after that the CCR hangs on kernel loading, on the serial console i saw a kernel panic.
I tried a netinstall with preserve configuration and netinstall told me cant mount filesystem because it is corrupted. I had todo a fresh install.
No issues after that, but i have a bad feeling about a fileystem corruption in runtime.
Update: i enabled store loggin on my CCR, i see that at random intervalls the message "adding new drive: micro-sd (/dev/mmcblk0)) appears, after that i see a message “web-proxy: activation finished successfully”.
20:20:18 store,debug adding new drive: micro-sd (/dev/mmcblk0)
20:20:18 store,debug web-proxy2: disk setup finished successfully
20:20:18 store,debug user-manager1: disk setup finished successfully
20:20:18 store,debug activating store for web-proxy2
20:20:18 store,debug web-proxy2: activation finished successfully
20:25:17 store,debug adding new drive: micro-sd (/dev/mmcblk0)
20:25:17 store,debug web-proxy2: disk setup finished successfully
20:25:17 store,debug user-manager1: disk setup finished successfully
20:25:18 store,debug activating store for web-proxy2
20:25:18 store,debug web-proxy2: activation finished successfully
20:26:05 store,debug adding new drive: micro-sd (/dev/mmcblk0)
20:26:05 store,debug web-proxy2: disk setup finished successfully
20:26:05 store,debug user-manager1: disk setup finished successfully
20:30:18 store,debug adding new drive: micro-sd (/dev/mmcblk0)
20:30:18 store,debug web-proxy2: disk setup finished successfully
20:30:18 store,debug user-manager1: disk setup finished successfully
20:30:18 store,debug activating store for web-proxy2
20:30:18 store,debug web-proxy2: activation finished successfully
20:33:20 store,debug adding new drive: micro-sd (/dev/mmcblk0)
20:33:20 store,debug web-proxy2: disk setup finished successfully
20:33:20 store,debug user-manager1: disk setup finished successfully
20:33:20 store,debug activating store for web-proxy2
20:33:20 store,debug web-proxy2: activation finished successfully
20:35:18 store,debug adding new drive: micro-sd (/dev/mmcblk0)
20:35:18 store,debug web-proxy2: disk setup finished successfully
20:35:18 store,debug user-manager1: disk setup finished successfully
20:35:18 store,debug activating store for web-proxy2
20:35:18 store,debug web-proxy2: activation finished successfully
20:36:05 store,debug adding new drive: micro-sd (/dev/mmcblk0)
20:36:05 store,debug web-proxy2: disk setup finished successfully
20:36:05 store,debug user-manager1: disk setup finished successfully
20:40:18 store,debug adding new drive: micro-sd (/dev/mmcblk0)
20:40:18 store,debug web-proxy2: disk setup finished successfully
20:40:18 store,debug user-manager1: disk setup finished successfully
20:40:18 store,debug activating store for web-proxy2
20:40:18 store,debug web-proxy2: activation finished successfully
20:45:17 store,debug adding new drive: micro-sd (/dev/mmcblk0)
20:45:17 store,debug web-proxy2: disk setup finished successfully
20:45:17 store,debug user-manager1: disk setup finished successfully
20:45:17 store,debug activating store for web-proxy2
20:45:17 store,debug web-proxy2: activation finished successfully
20:46:05 store,debug adding new drive: micro-sd (/dev/mmcblk0)
20:46:05 store,debug web-proxy2: disk setup finished successfully
20:46:05 store,debug user-manager1: disk setup finished successfully
