I have a question. It regards to the end of live for the CCR2116-12G-4S+. Currently we are running one unit in our premises, and we would like to buy a second one as a backup if God forbit anything happens to the one currently running.
Our goal is to mitigate downtime. Nevertheless, we are concerned a bit about end-of-life support.
What is MikroTik's Minimum Guarantee.?
From my understanding MikroTik's philosophy is more into Software side support rather than the hardware itself if hardware can handle the software, then is good and also if the software supports the architecture.
Can anyone advice on the matter and if we should get a second CCR2116-12G-4S+ And have it us a backup if something goes wrong with main Unit?
Warranty on hardware is pretty much standard, one or two years depending on the country Laws.
The statement about software is clear enough:
The device includes free software updates for the life of the product or a minimum of 5 years starting from date of purchase.
but historically it has been much longer than the 5 years promised, more like 15 or more.
If the router is part of a "mission critical" setup, having a second unit as spare is a very good idea.
And - while it makes little sense to repair the low cost devices, routers like the CCR2116 are usually worth the repair costs in case of a problem, depending on the country you are in distributors may have local repair services.
Thank you for your reply. We really appreciate the information provided.
Our main concern is the cost of this model in our location (Cyprus). A brand-new unit costs over €1,000, which is quite an investment for a device that will simply sit there and only be used if the main router fails.
The idea is to clone the main router's configuration and keep the backup powered off. Only if the main router fails would we replace it with the backup. We would also power on the backup whenever changes are made to the main router, transfer the updated configuration, and then power it back down.
Another concern is MikroTik's end-of-life support. We cannot predict the future, whether the main router will fail tomorrow or in 10 years, or whether MikroTik will introduce newer technology that makes this particular model obsolete. As you correctly pointed out, this is indeed a mission-critical system.
That is why we thought it would be worth asking for the community's opinion.
I guess, at the end of the day, it comes down to whether we are willing to bear the additional cost or not.
The reality is that we are not purchasing just this model. We also have other systems for which we plan to follow the same approach, keeping spare units as backups. Therefore, the overall cost will be considerably higher than just the price of the CCR2116-12G-4S+.
But we, users, do not know more hidden details of EOL support policy, especially in 10yers horizon.
2116 is a quite mighty device but it's not so special and unusual: 12Gb ports + 4 SFP+.
In case of fail, you can easily replace it with any such equipped device + properly cloned and applied configuration from the main device. Of course speeds would/could be lower but whole infrastructure would be working.
On the other hand: yes, 1000Eur means that 2116 is not in a "cheap" or "very cheap" league but it is not so much for a mission-critical device.
Just calculate/estimate:
how much 1h of failure/lack of connectivity would cost?
If more than 1000Eur then the answer is OBVIOUS.
That is a very valid point, and I agree that the cost of downtime should be a major factor in this decision.
However, considering the long-term hardware lifecycle and potential EOL support, would you recommend purchasing a cheaper compatible MikroTik as a cold spare today, or investing in an identical CCR2116 and periodically replacing it as the hardware approaches end of life?
For additional context, our CCR2116-12G-4S+ serves as the main router managing the entire network infrastructure, including our VLAN configurations.
Currently, we are using 4 Ethernet ports, 3 of which are connected to our primary ISP and backup internet connections. We also use 3 SFP+ ports connected to our network switches and UDM Pro, with the UDM Pro responsible for managing our wireless access points.
Considering its critical role, VLAN configurations, multiple WAN connections, and actual port requirements, would you recommend a cheaper MikroTik model that could serve as a reliable cold spare, even if it offers lower performance during an emergency?
If so, is there a specific model you would suggest we look into?
What are the current and future requirements? And who is responsible for managing the router?
Though you call it a valid point, I have the feeling that you are not aware of costs. Is my assumption correct that you are the tech person?
Can you explain what is mission critical from your perspective?
You are talking about EOL, why not about EOS?
When will hardware be depreciated for you? (not sure if this correct English...). When will it be replaced again?
Restoring a config, depending on the config itself (users/certificates/etc), can be done on different hardware. Not that difficult if you have the knowledge. What is the available knowledge on RouterOS?
IMHO a RB5009+a switch like the CRS305 might do, at about 1/3 of the cost.
But of course both maintaining the "emergency set" in sync with the main one and also the physical switching of the devices in case of need will become more complex.
All depends on traffic as it was written, so you have to judge yourself.
I would by same model to have 1:1 replacement but do not forget to switch it on from time to time to not let it to "rot from boredom and doing nothing"
If you do not want spent 1000Eur to not worry about the replacement device then consider CCR2004-1G-12S+2XS from the same "shelf" + a few RH-01 connectors.
Either procure a 1-on-1 replacement (and make sure to configure it already before). Don't complain then about the cost ... you pay insurance for other things as well, I suppose ? It's an insurance.
Or use another (cheaper/lighter) device, possibly even with a managed switch.
Also there, you need to configure it already before to make sure it will work once it needs to be called for duty.
Your decision.
As a reference (SOHO based): I was once goofing with my RB5009 at home and totally messed up but couldn't handle the issue right away.
A simple mAP served as router, a managed switch for the ethernet breakout and nobody here really complained (apart from the time which was needed to make the transition).
Since then I learned the value of partitions ... so some good came out if it as well.
Thank you all for your feedback and suggestions. I appreciate the different perspectives and recommendations.
Just to clarify, this is an inherited infrastructure, and we were not involved in the original network design or hardware selection. We are now responsible for maintaining it, and I am leading the research and implementation of a suitable backup solution.
We fully understand the financial impact of downtime. Our intention was never to question the importance of redundancy or avoid its cost, but rather to evaluate whether an identical replacement is necessary when a more cost-effective alternative could achieve the same objective.
Our question regarding EOL and EOS was also genuine, as we were not entirely familiar with how MikroTik handles long-term hardware support and product lifecycles. We wanted to better understand this before investing in equipment that might remain unused for several years.
Based on your suggestions, we will evaluate the CCR2116 as a direct replacement, alongside the RB5009 + CRS305 and CCR2004 as alternatives.
Our priority is to maintain essential network services during a failure, even at reduced performance. We will review our actual traffic and configuration requirements and ensure the chosen solution is properly tested beforehand.
The point I often try to make is that you can easily train anyone to swap two identical devices, it amounts to:
disconnect the failed device from mains
put the new device immediately below (or above) the failed one
going slowly from left to right extract a cable or SFP from the failed device and insert it firmly in the corresponding socket of the new device
loop to #3 until all cables have been transferred
connect new device to mains
While to replace a 2116 with a combo of RB5009+CRS305 is a little more complex and it would be easy to connect something to the "wrong" port.
If you (and/or your technicians) know where your towel is, you can setup an emergency temporary solution with almost any Mikrotik devices, as Holvoeth told, you could get away with - say - a hEX S (2025) and a CRS106-1C-5S with a cost in the order of magnitude of 1/8 of the 1000.
It's enough to mark ports with labels "A", "B", "C" ..... to have 1:1 explicit relation port to port when you use device with different port setup or numbering as a spare.
Even cables could be labeled with same labels as ports to have easy visual rocognition and matching. No excuses then that it wasn't properly described.
I know a NYC wireless ISP (NYC Mesh) who bought 1009s off eBay. I asked them why not buy a 2004, they said they "standardized" on a 1009 in some segments.
Yes, they'd rather use an EOS router. And I bet there are many other ISPs who do the same.
I don't think the 2116 will go EOL in a while. I'm more worried that if Putin invades Latvia and MT goes bust, or the FCC goes crazy and bans MT than the 2116 going EOL on its own.
Buy 1:1 replacement no matter how pricy it is to have simle&easy replacement
or buy a budget version that keeps your bussines going with some known limits in processing speed till you get a new "main device"
Cheap version has such an advantage that a new device could have much better efficiency than the contemporary pricy spare one when it will be needed, so the replacement would be additionaly an upgrade.
We use 1 CCR1072 as our main router and an exact 1:1 configured CCR1072 as a spare unit. Also a bunch of CCR1036s, a few PSUs of the 1036s died and we bought a few from AliExpress, because the PSUs were not available anymore.
You need always a spare unit. And i would suggest the same type, same hardware, same revision. Or you have to fiddle around with brainfuq like different port-names and such shit in an outage situation.
