I’m new here in this forum.
I’m just need some help guys.
Regarding cctv port forwarding..
How can I open port for cctv, because as I checked from the port checker website, my port for cctv is closed. How can I open a port?
I’m using mikrotik router. Should I open the port from the ISP?
Sorry I’m new in networking.
Config is OK, but 8000 is port for access by DVR software not from WEB interface, you need to configure 8080 port to on the same way as you have configured 8000! You need masquerade role too! If you have problems, please go to terminal and type export, and paste the results here!
CCTV Server and HTTP Port Forwarding in Mikrotic Router:
IP>Firewall>NAT
Chain: dstnat
Dst. Address: my Public IP
Protocol: tcp
Dst. Port: 8080 and 8000
Action: dst-nat
To Addresses: 192.168.9.120(My CCTV IP)
I can access my CCTV with my Public IP using HIKVision apps for windows/Mobile and WEB as well.
But using internet outside the network, I can't access both.
Your ISP router needs to forward these two ports to the Mikrotik router.
I assume that your connection is : Internet → ISP router (in router mode) → Mikrotik router.
so untill these ports are forwared on the ISP router, you won’t be able to access the DVR from the Internet.
Hi Sir,
I can access my dvr now. Now, I have a lot of dvr device, how can I put or access all my dvr?
Should I configure my dvr like these and to my router??
Please see below configuration:
CCTV IP Static: 192.168.9.120 to 192,168.9.129
Server Port: 8000 to 8009
HTTP Port: 8080 to 8089
CCTV Port Forwarding in Mikrotic Router:
IP>Firewall>NAT
Chain: dstnat
Protocol: tcp
Dst. Port: 8000 to 8009 and 8080 to 8089
Action: dst-nat
To Addresses: 192.168.9.120 to 192.168.9.129 (My CCTV IP)
To Ports: 8000 to 8009 and 8080 to 8089
Thank you for replying my post Sir. Appreciate it!
