CD-ISO
can we get a ISO release for the BETA’s?
I would really like to test them out, but I can’t load them on a virtual machine (where I do all my initial testing before ever installing on any real systems) because I can’t do a netinstall on a VM, only a floppy or CD boot…
Can you use netinstall ? I’ve used netinstall previously… both with the vfd and a pxe boot.
we will update the download page so you could install using CD install.
last night new ISO arrived....and i did install this morning...but.....!!!!!
has anyone success installing x86 v3-beta with CD-image [*.iso]
i tried around 6x, but not success...
last action reinstall with CDimage ..9.27 is ...ok, just comparing
system halted...!
anyone has idea..or i am wrong...!
Hasbullah.com
do you see any errors during the installation? can you try to install once more, and see if it works? we tested, it works.
yes, i saw an errors script e:g hotspot script failed... i saw around four errors but i didn't remember.
but for compairing i try other version is ok...e.g ....27 CDimage
!!license expired!!!
!!!system halted!!!
ok, when you say no problem, i will try to other new machine one.. :wink:
regards
Hasbullah.com
My experience with installing from ISO image into a QEmu virtual machine (where the 2.9.31 is running fine…):
Install will go through, system is rebooting, generating the SSH keys. Then after “Starting services…” I get a
Demo license expired!
Please reinstall the router.
connect failed (errno=2)
Shutting down...
Stopping services...
System halted.
Will have to try on a “real” system now :wink:
Best regards,
Christian Meis
Thanks cmit,
yes, i did try it. maybe 6x and same problem. and reinstall v...27 is OKAY. !!
i tried same report display like your post, ...tomorrow morning, i will try again with new machine.
i hope, tomorrow i will rokNroll with my son.... :wink:
regards
Hasbullah.com
this morning i am installing to new machine.
ok,....normis i think is enough to make install by CDimage, but the problem is same, maybe later i will try send/ask to support for the vBETA with CDimage
so, thanks
Hasbullah.com
I have the same problem here in one dell poweredge 850.
The only way to install it is using netinstall?
I have tryed the netinstall now, without succes again. The netinstall says that could not found the harddrive.
Please try again…
Durring install, MANY packages report script error on install.
On reboot, “demo license expired” please reinstall router..
OOPS…
Looks like a scripting isue durring the setup system.
Also FYI…
2.X boot floppies dont work with 3X netinstall (target does not register)
3X floppies do not boot.. (boot error and lock)..
PXE (older drivers limit install hardware.)
Tried with 3 systems from 3 vendors (dell, SuperMicro, Intel) All same results..
Did get to install via PXE on a super micro (p4 HT) na it saw the HT cpu as 2 cores… but this is a known flakey system and it was holding true to this .. so had to shut it down, dont want to test beta code on a Cra@ machine… :slight_smile:
Craig
I have tryed on my PE 850 with PXE without success.
The system boots, but dont recognize the SATA hd.
The machine doesn’t have any floppy drive then bootfloppy does not is one option.
The CD instalation does not work, after the boot I get the problem about the license.
I have tryed about ten times.
Yeh…
I tried the CD twice and then just threw it out…
I will just wait for a new iso build..
Craig
aggree, wait and see..for
Hasbullah.com
any news on a new cdISO???
I have a dell poweredge 850 too like caquino.
I have the same problem.
caquino if you could install and run RouterOS could you send me a mail with the solution, please (javaleroATunizar.es)
very...very frustated.. last month ago, i did try CDimage not success and try again with new beta2 is not success toooooooo...ooooo
what's happen....? or must be buy new license...? :wink:
anyone has advices, come please....!!!
i did install with standard procedure and standard packages too, from CDboot.
Hasbullah.com
please someone explain how you burn the images and how you install - the full process starting from downloading. we have tested and the CD images always work, so we must solve this with your help
yup...
anyone else come come come ..,please..!, i need your advices
regards
thanks
Hasbullah.com
balimore, please tell me step-by-step how you burn the image.
for example:
  1. download ISO with firefox from mirror 2
  2. use deep burner's command burn image to make bootable CD
  3. set BIOS of V8C-C1 motherboard to boot from CD
  4. disc was booted, started installation
  5. errors reporter after xxxx package tried to install
or even with more details
