Certificate Key Import not possible on v7.7
starting with RouterOS 7.7 i am not able to import a certificate key. The certificate is created with EasyRSA that we use a long time ago. I can import the certicate successfuly but not the key. With ROS 7.6 it works without any problems.
I got no error, it does nothing.
There are changes to certificate import in the changelog. Could it be a bug? How can i find out, where the problem is?
Tell me if you need some more details.
Thans a lot!
Best regards
Frank
I have same issue too. :frowning:
Regards
What kind of algorithms do you use? Starting from the RouterOS v7.7 some of the very old mechanisms as, for example, pkcs#7 encryption method “pbeWithSHA1And40BitRC2”, are not supported, since nowadays they can not be considered as “secure”.
thanks for your reply. We are using “sha256RSA”
Best regards
Frank
Works for me… So this is not a general problem with RouterOS 7.7. Can you give more detail on your certificate?
I can, but tell me what you need. If it’s not clear, we have no issues with the certificate, only with the Key.
We were seeing the same problems with certificates generated by EasyRSA. Up to v7.6 no issues, starting the v7.7 they refuse to import. The output is:
> /certificate import file-name="test.p12" name="test" passphrase=1234
     certificates-imported: 0
     private-keys-imported: 0
            files-imported: 0
       decryption-failures: 1
  keys-with-no-certificate: 0
EasyRSA uses OpenSSL to generate the p12 files with the default PKCS#12 algorithms. This gives:
# openssl pkcs12 -in test.p12 -info
Enter Import Password:
MAC Iteration 2048
MAC verified OK
PKCS7 Encrypted data: pbeWithSHA1And40BitRC2-CBC, Iteration 2048
Certificate bag
Bag Attributes
    localKeyID: 56 48 D7 2B F7 AA D7 4A 4A DB 80 16 90 D1 38 F9 C7 5C A3 44
    friendlyName: my test
subject=/CN=test
issuer=/CN=test CA
As stated above pbeWithSHA1And40BitRC2-CBC is no longer supported in v7.7. The solution is to change the ciphers in the OpenSSL pkcs12 export:
$ openssl pkcs12 -export -certpbe PBE-SHA1-3DES -keypbe PBE-SHA1-3DES ....
$ openssl pkcs12 -in test.p12 -info
MAC Iteration 2048
MAC verified OK
PKCS7 Encrypted data: pbeWithSHA1And3-KeyTripleDES-CBC, Iteration 2048
Certificate bag
Bag Attributes
subject=/CN=test
issuer=/CN=test CA
For EasyRSA you can set this in the appropriate line of the easyrsa script:
pkcs_opts="-certpbe PBE-SHA1-3DES -keypbe PBE-SHA1-3DES"
We do not have PKCS12, we use x509 Certificate with RSA key.
Signature Algorithm: sha256WithRSAEncryption
Public Key Algorithm: rsaEncryption
RSA Public-Key: (4096 bit)
For me it’s working again with routeros-7.8beta3.
Thanks!
That’s good news. Looks like I found a case where it is failing for me as well… Any chance we will see this in something like version 7.7.2?
SUP-106766 private-keys-imported: 0
NETINSTALLED 7.8beta3
[admin@MikroTik] > /certificate add common-name=r1-ca days-valid=3652 key-size=prime256v1 key-usage=key-cert-sign,crl-sign name=r1-ca subject-alt-name=email:r1-ca
[admin@MikroTik] > :do {/certificate sign [find name=r1-ca] name=r1-ca} on-error={:delay 3}
  progress: done
[admin@MikroTik] > /certificate export-certificate r1-ca file-name=r1-ca export-passphrase=passphrase type=pem
[admin@MikroTik] > /certificate remove r1-ca
[admin@MikroTik] > /certificate import file-name=r1-ca.crt name=r1-ca passphrase=passphrase
     certificates-imported: 1
            files-imported: 0
       decryption-failures: 0
[admin@MikroTik] > /certificate import file-name=r1-ca.key name=r1-ca passphrase=passphrase
            files-imported: 0
I had an issue importing certificates, I checked my certificate and It had some blanck rows at the end. After deleting those rows I could import the certificate
This worked for me as well!
I was also having problems importing certificates+key in PKCS#12 format, using a file generated by OpenSSL from PEM files with key and certificate (Lets Encrypt - using a script that is a few years old).
I can confirm that the by default OpenSSL will use pbeWithSHA1And40BitRC2 unless RC2 is disabled or -descert option is used. By using -descert the resulting PKCS#12 file uses pbeWithSHA1And3-KeyTripleDES that is (still) accepted by ROS 7.7.
Knowing that pbeWithSHA1And40BitRC2 is no longer accepted was key. A small fix in my script and voila!
I’m having the same problem. just implemented two new Mikrotiks freshly done with netinstall to v7.8.
I’m using the Posh-ACME service (targeting ZeroSSL) to generate the certificates on another machine and those are being put onto the units to be imported. I have updated to the latest version and have added the “-UseModernPfxEncryption” to the certificate generation process, but I am still running into the issue.
When I import the certificate files (pfx full chain + key file) it gives me this output:
            files-imported: 1
  keys-with-no-certificate: 1
Where am I going wrong?
PS: key file imports, its the pfx that is now not importing (did on previous versions).
Lets Encrypt client 0.38 le64.exe
The created crt does indeed have 2 blank lines at the very end
That was not a problem ever up to 6.48.7
Now upgraded to RB4011 which came with factory 7.8 and these 2 lines cause issue of not importing crt (but also not failing explicitly)
Once removed, the import works again. IMO that is a bug
sebus
I cloud not import the root ca cert of let’s encrypt (ISRG Root X1). In my case I had to covert the file to unix line endings, the downloaded one had windows.
  model: RB960PGS
  revision: r2
  firmware-type: qca9550L
  factory-firmware: 6.44.6
  current-firmware: 7.10.1
  upgrade-firmware: 7.10.1
This can be done in any good editor, in my case vim
:set fileformat=unix
to save and quit in vim
:x
Same problem here. Will try to update to v7.11 where some certificate bugs are fixed (as mentioned in changelog).
Error that RouterOS v. 7.13.1 does not import certificate with CRLF line endings (in editor visible as ^M$) seems to be persist. My *.pem file was downloaded with Firefox browser on linux system.
I’ve converted line endings with vim and all is ok.
I switched to a full chain cer+key instead of my original full chain pfx+key, this solved my issues on all versions I have tried it on (old and new).
I have not tested yet on v13.5 (or newer), but I’m confident my problem is no more.
