I follow https://www.ollegustafsson.com/en/letsencrypt-routeros/ to enable https with let’s encrypt. I got .cer and .key imported into mikrotik. I successful imported .cer file into certificate but mikrotik won’t import .key into certificate. What is the problem?
[admin@WingTik] > /certificate import file-name=domain.example.com.cer passphrase=""
certificates-imported: 1
private-keys-imported: 0
files-imported: 1
decryption-failures: 0
keys-with-no-certificate: 0
[admin@WingTik] > /certificate import file-name=domain.example.com.key passphrase=""
certificates-imported: 0
files-imported: 0
[admin@WingTik] > /certificate print
Flags: K - private-key, D - dsa, L - crl, C - smart-card-key, A - authority, I - issued, R - revoked, E - expired, T - trusted
# NAME COMMON-NAME SUBJECT-ALT-NAME FINGERPRINT
0 L T domain.example.com.cer_0 Let's Encrypt Authority X3 25847d668eb4f04fdd40b12b6b0740c567da7...
[admin@WingTik] > /system resource print
uptime: 4h17m21s
version: 6.39 (stable)
build-time: Apr/27/2017 10:06:08
factory-software: 6.34.2
free-memory: 99.9MiB
total-memory: 128.0MiB
cpu: MIPS 74Kc V5.0
cpu-count: 1
cpu-frequency: 720MHz
cpu-load: 2%
free-hdd-space: 5.1MiB
total-hdd-space: 16.0MiB
write-sect-since-reboot: 1938
write-sect-total: 4564
bad-blocks: 0%
architecture-name: mipsbe
board-name: hAP ac
platform: MikroTik
