Change port on BTest Server and the Bandwidth Test
I use the “BTest Server” and the “Bandwidth Test” client between a 4G WAP LTE router and a CCR on a fiber link.
Most of the time it works well, except on some 4G operator which blocks the TCP 2000 port …
How could I modify the TCP port “BTest Server” and the client “Bandwidth Test” in order to make them work when the TCP port 2000 is blocked?
Thanks for your help.
Hello Team,
i hav the same topic.
fortigate in standard config can not forward the port 2000.
https://community.fortinet.com/t5/FortiGate/Troubleshooting-Tip-SCCP-TCP-port-2000-traffic-stops-working/ta-p/338769
please make the port flexible.
A variable port can also help me to test the connection in the SD-WAN individually.
(we use an AAR that makes it possible to assign different ports or applications to the appropriate path)
Best Christmas wishes.
Marcus
