change start Map
How do I change the main panel when Dude starts? It was coming up on the right Map but now it always comes up with the device screen.
The dude remembers the last map you had open when you close it. Make sure to close it on your main map. Also any other computers you have connected change them to the main map and close/re-open the dude and that is where it will start.
HTH,
lebowski
Dude will restart at the map you were on when you closed it - if you are a Read/Write user. If you are a Read Only user it will always start up on the same map, no matter which map you were on when you closed it down. If you want a Read Only user to start on a particular page you need to temporarily give them Read/Write status, get them to navigate to the map they want to start on, then close down The Dude. Then make them a Read Only user again and they will always start on the map that they have selected.
Good point geoffsmith31 thanks for the additional details.
