Changing routers password via Dude
Hi There,
We have several MT routers running over the Dude 6.36 and we are wanting to change all the router passwords. Is it possible to do it via Dude? if yes, what would be required?
Thanks,
Pipa
I also could not find it. So I solved it with http://wiki.mikrotik.com/wiki/Semi-Automating_CPE_ROS/Firmware/script_updates_and_setting_changes. In the upgrade file you could put something like;
/user
set [find name=“admin”] password=YourPassword
I have 61 devices, but that will be a number of 450 in four months. A lot to do and it would be a great feature
