Chateau 5G R17 ax loses cellular internet every few days
My first time posting here so please let me know if I need to make changes or additions to this post or ask it elsewhere.
My devices are loosing internet connection every few days through my Mikrotik router at home. Always when I wake up IIRC. I'm using a post-paid SIM card from Digi Mobil (Spain) with unlimited data. I tried disabling and enabling the LTE interface to restore the connection but this doesn't work. Unplugging the router works; internet is restored after it boots.
Here is the export:
\[admin@MikroTik\] > export compact
\# 2025-12-22 09:57:07 by RouterOS 7.20.4
\# software id = HT8G-SXVF
\# model = S53UG+5HaxD2HaxD&RG650E-EU
\# serial number = removed
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no comment=defconf name=bridge
/interface wifi
set \[ find default-name=wifi1 \] channel.band=5ghz-ax .skip-dfs-channels=10min-cac .width=20/40/80mhz configuration.country=Spain .mode=ap .ssid=MikroTik-6B4AF5-5G disabled=no \\ security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set \[ find default-name=wifi2 \] channel.band=2ghz-ax .skip-dfs-channels=10min-cac .width=20/40mhz configuration.country=Spain .mode=ap .ssid=MikroTik-6B4AF5-2G disabled=no \\ security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
/interface ethernet switch
set 0 cpu-flow-control=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add apn=internet authentication=pap name=Orange user=orange
add apn=internet.digimobil.es authentication=pap ip-type=ipv4 name=DIGI
/interface lte
set \[ find default-name=lte1 \] allow-roaming=yes apn-profiles=DIGI band="" nr-band=""
add address-pool=default-dhcp interface=bridge name=defconf
/queue type
add fq-codel-ecn=no kind=fq-codel name=fq-codel-ethernet-default
/queue interface
set ether1 queue=fq-codel-ethernet-default
set ether2 queue=fq-codel-ethernet-default
set ether3 queue=fq-codel-ethernet-default
set ether4 queue=fq-codel-ethernet-default
set ether5 queue=fq-codel-ethernet-default
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add comment=defconf interface=lte1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ipv6 firewall address-list
add address=2001:10::/28 comment="defconf: ORCHID" list=bad_ipv6 add address=3ffe::/16 comment="defconf: 6bone" list=bad_ipv6
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" connection-state=established,related
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Madrid
/system logging
set 1 action=disk
set 3 action=disk
add topics=lte
add topics=lte
/system routerboard mode-button
set enabled=yes on-event=dark-mode /system routerboard wps-button
set enabled=yes on-event=wps-accept /system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=\*sys policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\\r\\
\\n :if (\[system leds settings get all-leds-off\] = \\"never\\") do={\\r\\
\\n /system leds settings set all-leds-off=immediate \\r\\
\\n } else={\\r\\
\\n /system leds settings set all-leds-off=never \\r\\
\\n }\\r\\
\\n "
add comment=defconf dont-require-permissions=no name=wps-accept owner=\*sys policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=\\ "\\r\\
\\n :foreach iface in=\[/interface/wifi find where (configuration.mode=\\"ap\\" && disabled=no)\] do={\\r\\
\\n /interface/wifi wps-push-button \\$iface;}\\r\\
\\n "
/tool mac-server
/tool mac-server mac-winbox
If anyone is able to help I would be most grateful. Thank you very much, and I hope you all have a good holiday season.
Best regards,
Polka
It is unusual that resetting LTE it doesn't resume connection, there is the need of a delay after disabling LTE interface before re-enabling it, maybe if you have one it is too short?
The typical script would be something like :
:if ([/ping 8.8.8.8 count=10 size=64 interval=2s]=0) do={
	:log error "LTE DOWN";
	/interface disable lte1
	/delay 5s
	/interface enable lte1
} else={
	:log info "LTE FINE";
Thanks for the quick response.
When I tried to disable and enable lte earlier today it was through the web GUI. However, it did not enable when clicking the toggle button. I’ve had this issue a couple times where the GUI, in particular the GUI for the LTE interface, does not respond. When it doesn't respond, the terminal window doesn't respond either. Closing the page in the web browser, waiting a while, and then reopening it seems to restore control sometimes.
I was able to get the script saved and it runs.
Is there a way to have this script run in the background? Perhaps with something like while 1? Or is it possible to have something events based?
Thanks again,
Polka
There are basically two ways:
  1. scheduler (setting it to run every n minutes, hours or days)
  2. netwatch (setting the disable/delay/enable in the DOWN script)
The first is better if the disconnection happens less than daily or so, you set it up to run at (say 4:00 AM) every morning, and it is unlikely to be even noticed by users and - in most cases - it will be enough.
The second is better if the disconnections happen more often and "casually", you set the netwatch to run (say) every 10 minutes and you are all set, BUT there is the risk of unneded interface resets if the connection towards the canary address (8.8.8.8 in this example) is broken/intermittent for some other reasons.
Same goes for logging, if you want to log the up and downs to observe the behaviour it is fine, otherwise it doesn't make much sense to have - before or later - the log full of these messages, there will be - I believe automatic ones for LTE disable/enable.
JFYI, there is a (supoposed) fix for a very similar problem, specific to your device in 7.21rc3:
V7.21rc [testing] is released! - #141 by EdPa
Maybe you can wait for a stable release of 7.21 and then try it.
Many thanks for the tips and help, jaclaz! I’ll try the new version when it's in stable.
Best regards,
Polka
hello,
i hope it will be a fix for my enviroment too, based on hap ax3 and a m.2/usb3 modem with similar quectel hardware (rm520ngl) of chateau, in my tests i see many lost of connection while doing a speed test on ookla or google website.
with netwatch i can disable/enable interface, but i think the problem is on modem firmware.
thanks for the information
I upgraded to 7.21.1 and now I have no internet over LTE. I can’t ping 1.1.1.1 or 8.8.8.8 from the router terminal. Under lte1 under cellular I see my operator and other info still. I also see a small burst of traffic on the graph at the bottom. I’ve tried changing the APN settings to
- the default
- to what I can see on my cell phone (same operator)
- IPv4
- Use Network APN
- authentication none
- authentication PAP with no user or password.
In the log I see lte1 qmi: dropped reply, lte1 qmi traffic collision, and lte1 forced reconfiguration due to difficulty setting link up.
Any help would be greatly appreciated.
Downgrade back to 7.20.7 or 7.20.
Never upgrade for the sake of upgrading.
There is a problem with 7.21.1 specifically for this device/modem.
... one step forward, two steps back ... :roll_eyes:
Hello;
not sure whether this should be posted to the new support page or here .. but I also have a new Chateau 5G R17 ; delivered with August ‘25 firmware.
I have updated it to 7.22.1 and am attempting to get a Smarty eSIM provisioned.
Does 7.22.1 fix the issue highlighted in January ? (I need to check the release log…)
This thread is one of the few Google hits on the log message error that preceeds the provisioning fail (by a few minutes) “lte1 qmi: unexpected transaction error…“
So I am wondering …does the routeros npk bundle (and/or the qcom-wifi npk bundle) contain an update to the 5G modem firmware (because I saw references on a separate forum specifically to modem firmware versions) ??
& if so, which one to use ?
I need the Chateau to work “now” … (4G signal looks OK from a ‘phone and operator coverage map viewpoint,5G not on maps but a ‘phone shows it sometimes..) .
I have a separate question about the provisioning process, but will look to see if there are more appropriate threads for that topic..
thanks &
regards,
Charlie
Well, then google is wrong :astonished_face: as in this thread it seems like the only reference to that error is your post.
This thread is about an issue where connection is correctly established but after a few hours/days is lost and doesn't resume automatically.
hello guys,
take my suggestion as an idea about lte “random” disconnections.
i’m using a m.2/usb adapter with a 5g modem similar to the one on chateau.
And i have disconnections whenever i stress the lte/5g interface after i start a download or a stream, very frustrating but with a netwatch rule, it can be partially fixed
Debug with a bts, based on my experiences, are quite impossible, without a tech guy who can check in real time the other side of network.
So i tested everything, from directive antennas to heatshield/temp on modem or power adapter but 99,999% is due to pcc/scc bands from same bts with different sinr/rsrp in the same time, so in my enviroment if i use 1+3 lte and n28 on dss 5g nsa, i have no disconnections and best effort; my rm520ngl is capable of 1pcc+2scc, but your rg650 should do better.
So i suggest you to monitor which pcc/scc combination is the best for your radio link ….
i still have an open tkt with Mikrotik support about it.
