Chateau LTE-12
If you don’t use zerotier remove that package, npk itself is 750Kb, I guess when installed is even more because of compression.
On mine device without zerotier disk space is
free-hdd-space: 1096.0KiB
total-hdd-space: 15.2MiB
Probably this issue would be on my device also if zerotier is installed…
I think it was mistake from MT to build quite powerful (and not cheap) device like LTE12 with only 16Mb disk space because it’s limiting which packages can be installed (rose-storage, dude…).
No, I´m not using Zerotier on this unit but I´m running a EoIP tunnel over SSTP on it though.
I have get rid of the MEMORY_FULL issue. After a while about 15-20 SMS in the inbox got visible, upon deleting those I can send and receive SMS again.
So for the moment it´s running as it should, maybe the netinstall solved a couple of issues. I have to wait an see..
Thank you all for supporting me in this issue!
