Hi everyone,
I’ve got a problem with my Chateau LTE18 ax. Since a power outage a few days ago, no 2.4GHz Wifi is working anymore. I checked for firmware upgrades, but I already installed the latest. Here are some details:
Firmeware: RouterOS + wifi-qcom Version 7.14.3
Behaviour:
wifi1 (5GHz-ax) and wifi2 (2GHz-n) interfaces are configured exactly the same. However, the 5GHz SSID shows up, while the 2.4GHz SSID is not showing up
When starting a Wifi scan with wifi1 (5GHz), other networks are found. When scanning on wifi2 (2.4GHz), nothing shows up (but there should).
In my opinion, my problem could have two reasons:
Possible Reason 1: wifi2 is broken
Possible Reason 2: the router installed a firmware upgrade after reboot, since then, the correct drivers are not installed anymore. However, I manually tried reinstalling the wifi-qcom packet without any change.
You were right concerning the firmware. Current-Firmware and upgrade firmware were not the same. I upgraded, now the firmware is up-to-date, but the issue persists.
No, unfortunately, no unusual logs in the system log.
As far as I know, a wireless interface is only marked as running, when a client is connected. Unless, no client is connected, no running flag is displayed.
For quick checking if it works, I am using NetSpot for Android. Not the most professional tool, but still a reliable one.
To really make sure if the 2.4GHz “wifi2” is there (or not), I am disabling the 5GHz “wifi1” on the router and check with my notebook and smartphone if I can find my SSID.
As you said initially that wifi2 was working and just after a power outage it was gone - it could possibly be a hardware defect indeed.
Could not harm to contact Mikrotik support → https://mikrotik.com/support
Create a supout.rif and attach it to your helpdesk issue. Maybe even include the URL to this forum topic along with your issue description.
