Does anyone know of a cheap cable dsl router that works with Mikrotik? We were using Linksys but recently there quality control is horrible. Thought about using the Netgear RP614 but for some reason Netgear routers will not work with Mikrotik PPPoE servers.
We are using Netgear RP614v2 routers with MikroTik PPPoE servers with good success.
One thing I seem to remember though is that you have to disable mschap1 and/or mschap2, otherwise the RP614v2 wouldn’t authenticate. But not sure about this, you should test in your lab, as this issue has been seen some time ago…
