I have this router which has the entire Internet routing table. However I find it difficult to show any routes for troubleshooting purpose since it took 8 minutes to complete a command… For example, if I want to see how to reach 1.1.1.1, so I ran
/ip route print where 1.1.1.1 in dst-address
And it will take a long time…
I am also wondering how to check the actual BGP table instead of routing table.. For example this router peer with two uplink ISPs so how to check the BGP route that is less preferred? I think I am just looking for Cisco equivalent command “show ip bgp 1.1.1.1” which also tells me other BGP attributes such as local preference, metric, …etc..
When the routing table is small, there’s almost no need for route table search commands.
When you have a huge routing table, that’s the only thing that even remotely makes sense.
Yet - it takes 8 minutes to see a route table entry via search on a full BGP table…
I’ve only ever run Cisco routers with a full table. I can say for sure that I would switch from Mikrotik to Cisco for this one reason alone. Don’t get me wrong, I love Mikrotiks (I participate in the forums even though I’ve been at my current job for over two years and we don’t even use Mikrotik) - they’re one of the best boxes out there for so many things…
But this one behavior alone would prevent me from using ROS in a production BGP environment.
“show IP route x.x.x.x m.m.m.m” is near-instantaneous, and to say that I used this command every day would be like saying the Sun is hot… “show ip bgp x.x.x.x/m” is also lightning fast, and another indispensable tool. If BGP routing is like carpentry, these two tools are like a hammer and a screwdriver. If you don’t have them, you aren’t a carpenter.
It is hard to say for version that will be available for masses, but right now it is
[admin@MikroTik] /routing route> :put [:time [print where 192.0.128.1 in dst-address] ]
DST-ADDRESS GATEWAY DISTANCE
AS> 0.0.0.0/0 10.5.101.1 0
S 0.0.0.0/0 10.5.101.1 1
D bY 192.0.128.0/17 10.5.101.1 20
00:00:00.010344
