I have a Provider, which has its first hop within the local POP. This means, if there is an issue outside the local POP, the gateway still can be pinged. But connection to the Internet is not available anymore.
Due to this circumstance, the route, even with check-gateway enabled, still keeps being active when the Provider has issues within its network.
P.S. I'm also having issues with Fasttrack and the mangle rule. If I mangle it to this test table with Fasttrack enabled, the performance is terrible. Speedtest with just a few kb/s. Is this normal? Traffic over the main table over the same gateway is OK with Fasttrack enabled.
A config is not snippets… and not into chasing moving targets!
Provide a network diagram ( should detail any vlans, WAN sources and type ( static,dynamic, public, not publice )
Provide a complete config
Provide requirements
a. identify all user(s)/device(s) and groups of users/devices including admin
b. identify all the traffic they require.
