In Scheduler I have a task to run every 1 minute, but I would like that if after 10 attempts (10 minutes) it could not connect to the other end, to try again after 60 minutes. Is there any way to do it?
Curious as to why you ping an internal WG address to see if connection is up??
Assuming this is a client router and the subnet is on the other router??
The thought behind netwatch with a “On Test”/on-test= script is that it runs after each netwatch test. So if the interval is 00:00:30, the “On Test” script runs every 30 seconds, just like a scheduled script. The “On Test” run regardless if the test is successful/failed, so the “On Test” script with interval= is almost same as schedule script.
Now important difference is you already have the results of the ping check available in the netwatch “On Test” script, without having to invoke /ping yourself in scheduler. Importantly, netwatch monitor has a “since” field that reflect the last status change, you can use that to determine if it’s been “too long” since last successful ping test, and then do the restart.
I don’t have time to write an example today. The annoying part is that “since” is actually a string, not a time, so you need convert the string from the “since” field. So you’ll need use one of @rextended snippets to convert the string in “since” field from netwatch (apr/20/2023 04:20:00) into “time”, then you can compare it with some “:if ($parsed-since-as-time < ([:timestamp] - 10m)) do={#restart WG}” in your “On Test” script to try the restart. Not saying better/worse – likely more flexible since netwatch let you define all “icmp” test parameters in netwatch, and then have you “On Test” do the restart if down “too long”.
Also “On Down” script might also do the restart of WG might be used too. Although you’d want the interval= to be at least 00:01:00 and/or set “start-delay=” to same.
The critical thing in all cases is to use the “icmp” test type in netwatch, not “simple”, as icmp one does a few pings, just like the schedule code above.
