I have been trying to install the CHR image on an OVH VPS but continually get the “No harddrives found” error.
Someone has had a similar issue: http://forum.mikrotik.com/t/error-in-virtio-disk-driver-in-6-31/90727/1 however they were using the standard ISO rather than the CHR image.
Very much am using the chr-6.34.1.img and the VM boots into the installer, but then throws the “FATAL ERROR: no hard drives found”.
The exact procedure i have taken is:
- Created a Win2012R2 VM.
- Attach a 10GB HDD to it.
- Download the CHR image file listed above.
- Used this tool: http://hddguru.com/software/HDD-Raw-Copy-Tool/ to write the image to the drive.
- Rebooted the VM to the newly written drive.
- Installer starts, then throws No harddrives found error.
EDIT:
I just tried again using CentOS and DD to write the raw image to the disk. Same issue:
Below is a hwinfo printout of that same VM booted into CentOS 7.
server-2
description: Computer
product: OpenStack Nova
vendor: OpenStack Foundation
version: 2014.2.3
serial: c7fb1b80-d3c8-11e4-8000-001e67caded6
width: 64 bits
capabilities: smbios-2.4 dmi-2.4 vsyscall32
configuration: boot=normal uuid=0D08F27A-D5C4-4330-B7E7-C8AF5F0B95CE
*-core
description: Motherboard
physical id: 0
*-firmware
description: BIOS
vendor: Bochs
physical id: 0
version: Bochs
date: 01/01/2011
*-cpu
description: CPU
product: Intel Xeon E312xx (Sandy Bridge)
vendor: Intel Corp.
physical id: 401
bus info: cpu@0
slot: CPU 1
capacity: 2GHz
width: 64 bits
capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss syscall nx pdpe1gb rdtscp x86-64 constant_tsc rep_good nopl eagerfpu pni pclmulqdq vmx ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm xsaveopt vnmi ept fsgsbase bmi1 avx2 smep bmi2 erms invpcid
*-memory
description: System Memory
physical id: 1000
capacity: 4000MiB
*-bank
description: DIMM RAM
physical id: 0
slot: DIMM 0
width: 64 bits
*-generic:0 UNCLAIMED
physical id: 1
bus info: parisc@1
*-generic:1 UNCLAIMED
physical id: 10
bus info: parisc@10
*-generic:2 UNCLAIMED
physical id: 108
bus info: parisc@108
*-generic:3 UNCLAIMED
physical id: 11
bus info: parisc@11
*-generic:4 UNCLAIMED
physical id: 112
bus info: parisc@112
*-generic:5 UNCLAIMED
physical id: 113
bus info: parisc@113
*-generic:6 UNCLAIMED
physical id: 115
bus info: parisc@115
*-generic:7 UNCLAIMED
physical id: 116
bus info: parisc@116
*-generic:8 UNCLAIMED
physical id: 12
bus info: parisc@12
*-generic:9 UNCLAIMED
physical id: 13
bus info: parisc@13
*-generic:10 UNCLAIMED
physical id: 136
bus info: parisc@136
*-generic:11 UNCLAIMED
physical id: 14
bus info: parisc@14
*-generic:12 UNCLAIMED
physical id: 142
bus info: parisc@142
*-generic:13 UNCLAIMED
physical id: 143
bus info: parisc@143
*-generic:14 UNCLAIMED
physical id: 144
bus info: parisc@144
*-generic:15 UNCLAIMED
physical id: 15
bus info: parisc@15
*-generic:16 UNCLAIMED
physical id: 16
bus info: parisc@16
*-generic:17 UNCLAIMED
physical id: 17
bus info: parisc@17
*-generic:18 UNCLAIMED
physical id: 18
bus info: parisc@18
*-generic:19 UNCLAIMED
physical id: 19
bus info: parisc@19
*-generic:20 UNCLAIMED
physical id: 2
bus info: parisc@2
*-generic:21 UNCLAIMED
physical id: 20
bus info: parisc@20
*-generic:22 UNCLAIMED
physical id: 205
bus info: parisc@205
*-generic:23 UNCLAIMED
physical id: 21
bus info: parisc@21
*-generic:24 UNCLAIMED
physical id: 210
bus info: parisc@210
*-generic:25 UNCLAIMED
physical id: 214
bus info: parisc@214
*-generic:26 UNCLAIMED
physical id: 22
bus info: parisc@22
*-generic:27 UNCLAIMED
physical id: 227
bus info: parisc@227
*-generic:28 UNCLAIMED
physical id: 234
bus info: parisc@234
*-generic:29 UNCLAIMED
physical id: 24
bus info: parisc@24
*-generic:30 UNCLAIMED
physical id: 25
bus info: parisc@25
*-generic:31 UNCLAIMED
physical id: 26
bus info: parisc@26
*-generic:32 UNCLAIMED
physical id: 27
bus info: parisc@27
*-generic:33 UNCLAIMED
physical id: 273
bus info: parisc@273
*-generic:34 UNCLAIMED
physical id: 28
bus info: parisc@28
*-generic:35 UNCLAIMED
physical id: 286
bus info: parisc@286
*-generic:36 UNCLAIMED
physical id: 29
bus info: parisc@29
*-generic:37 UNCLAIMED
physical id: 3
bus info: parisc@3
*-generic:38 UNCLAIMED
physical id: 302
bus info: parisc@302
*-generic:39 UNCLAIMED
physical id: 303
bus info: parisc@303
*-generic:40 UNCLAIMED
physical id: 306
bus info: parisc@306
*-generic:41 UNCLAIMED
physical id: 308
bus info: parisc@308
*-generic:42 UNCLAIMED
physical id: 313
bus info: parisc@313
*-generic:43 UNCLAIMED
physical id: 319
bus info: parisc@319
*-generic:44 UNCLAIMED
physical id: 320
bus info: parisc@320
*-generic:45 UNCLAIMED
physical id: 321
bus info: parisc@321
*-generic:46 UNCLAIMED
physical id: 38
bus info: parisc@38
*-generic:47 UNCLAIMED
physical id: 39
bus info: parisc@39
*-generic:48 UNCLAIMED
physical id: 40
bus info: parisc@40
*-generic:49 UNCLAIMED
physical id: 41
bus info: parisc@41
*-generic:50 UNCLAIMED
physical id: 5
bus info: parisc@5
*-generic:51 UNCLAIMED
physical id: 550
bus info: parisc@550
*-generic:52 UNCLAIMED
physical id: 6
bus info: parisc@6
*-generic:53 UNCLAIMED
physical id: 60
bus info: parisc@60
*-generic:54 UNCLAIMED
physical id: 61
bus info: parisc@61
*-generic:55 UNCLAIMED
physical id: 7
bus info: parisc@7
*-generic:56 UNCLAIMED
physical id: 713
bus info: parisc@713
*-generic:57 UNCLAIMED
physical id: 739
bus info: parisc@739
*-generic:58 UNCLAIMED
physical id: 741
bus info: parisc@741
*-generic:59 UNCLAIMED
physical id: 742
bus info: parisc@742
*-generic:60 UNCLAIMED
physical id: 8
bus info: parisc@8
*-generic:61 UNCLAIMED
physical id: 84
bus info: parisc@84
*-generic:62 UNCLAIMED
physical id: 851
bus info: parisc@851
*-generic:63 UNCLAIMED
physical id: 852
bus info: parisc@852
*-generic:64 UNCLAIMED
physical id: 9
bus info: parisc@9
*-pci
description: Host bridge
product: 440FX - 82441FX PMC [Natoma]
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 02
width: 32 bits
clock: 33MHz
*-isa
description: ISA bridge
product: 82371SB PIIX3 ISA [Natoma/Triton II]
physical id: 1
bus info: pci@0000:00:01.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: isa
configuration: latency=0
*-ide
description: IDE interface
product: 82371SB PIIX3 IDE [Natoma/Triton II]
physical id: 1.1
bus info: pci@0000:00:01.1
version: 00
width: 32 bits
clock: 33MHz
capabilities: ide bus_master
configuration: driver=ata_piix latency=0
resources: irq:0 ioport:1f0(size=8) ioport:3f6 ioport:170(size=8) ioport:376 ioport:c0a0(size=16)
*-usb
description: USB controller
product: 82371SB PIIX3 USB [Natoma/Triton II]
physical id: 1.2
bus info: pci@0000:00:01.2
version: 01
width: 32 bits
clock: 33MHz
capabilities: uhci bus_master
configuration: driver=uhci_hcd latency=0
resources: irq:11 ioport:c040(size=32)
*-usbhost
product: UHCI Host Controller
vendor: Linux 3.10.0-229.1.2.el7.x86_64 uhci_hcd
physical id: 1
bus info: usb@1
logical name: usb1
version: 3.10
capabilities: usb-1.10
configuration: driver=hub slots=2 speed=12Mbit/s
*-usb
description: Mouse
product: QEMU USB Tablet
vendor: QEMU
physical id: 1
bus info: usb@1:1
version: 0.00
serial: 42
capabilities: usb-2.00
configuration: driver=usbhid maxpower=100mA speed=12Mbit/s
*-bridge
description: Bridge
product: 82371AB/EB/MB PIIX4 ACPI
physical id: 1.3
bus info: pci@0000:00:01.3
version: 03
width: 32 bits
clock: 33MHz
capabilities: bridge
configuration: driver=piix4_smbus latency=0
resources: irq:9
*-display
description: VGA compatible controller
product: GD 5446
vendor: Cirrus Logic
physical id: 2
bus info: pci@0000:00:02.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: vga_controller rom
configuration: driver=cirrus latency=0
resources: irq:0 memory:fc000000-fdffffff memory:febd0000-febd0fff memory:febc0000-febcffff
*-network
description: Ethernet interface
product: Virtio network device
vendor: Red Hat, Inc
physical id: 3
bus info: pci@0000:00:03.0
logical name: eth0
version: 00
serial: fa:16:3e:fa:b5:8c
width: 32 bits
clock: 33MHz
capabilities: msix bus_master cap_list rom ethernet physical
configuration: broadcast=yes driver=virtio_net driverversion=1.0.0 ip=167.114.242.1 latency=0 link=yes multicast=yes
resources: irq:10 ioport:c060(size=32) memory:febd1000-febd1fff memory:feb80000-febbffff
*-scsi
description: SCSI storage controller
product: Virtio block device
physical id: 4
bus info: pci@0000:00:04.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: scsi msix bus_master cap_list
configuration: driver=virtio-pci latency=0
resources: irq:11 ioport:c000(size=64) memory:febd2000-febd2fff
*-generic
description: Unclassified device
product: Virtio memory balloon
physical id: 5
bus info: pci@0000:00:05.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: bus_master
resources: irq:10 ioport:c080(size=32)
